gears!!!
Jan 14, 2008 | 02:19 AM
gears!!!
i did have an 87 with 3.07 and auto i want to change gears but i im now at +/-2100 rpm at 75 mph so what will be the difference in performance and rpm at high speed with 3.73 or 4.10
will 4.10be too much or ok with overdrive
Jan 14, 2008 | 02:21 AM
i im also running 275/40/18's in the back and will be on 295/35/18's very soon!!!
Jan 14, 2008 | 02:31 AM
St. Jude Donor '11,'14
From what I have read the 3.07 is best overall for stock L98. I don't have any experience but I have read a few posts.
Kevin
Jan 14, 2008 | 06:16 AM
Quote:
Originally Posted by
fast red 87 vette
If you still plan on running the stock intake. DO NOT change the gears.
Jan 14, 2008 | 10:33 AM
I have 4.11's for 100 bucks brand new with master kit for sale if you go that route
Jan 14, 2008 | 12:42 PM
88BlackZ-51
One of my buddies told me the same thing, why???
Jan 14, 2008 | 02:48 PM
alecracing
I think it's because L98's make most of their power down low, and your going to take your self out of that rpm range where your making the most pretty quickly with those gears (my .02 anyways)
Jan 14, 2008 | 04:40 PM
alecracing
because of the torque band of the L98.
Jan 14, 2008 | 06:04 PM
Do NOT change to such a low gearset if you plan to keep it with a TPI intake.
Jan 14, 2008 | 06:36 PM
From: One day you're a Comet...the next day you're dust... Arkansas
You will probably lower your 1/4 time.
Jan 14, 2008 | 08:31 PM
I have a 93 so not sure it applies but 373 gears at 2500RPM = 65 MPH
Jan 14, 2008 | 08:49 PM
do u have an auto? I have 4.11's and im at 1900 at 65. u must be in 5th gear
Jan 14, 2008 | 09:09 PM
BADDUCK
No, it'll probably raise his 1/4mi time.
Jan 14, 2008 | 11:00 PM
3.07 is the gear ratio for the TPI intake. It runs out of breath at 4500 (at best) so you want to keep the revs down where it makes most of its power.
