Re-Torque Head Bolts Procedure
Old Jan 14, 2008 | 09:54 PM
djxib's Avatar
djxib
Default Re-Torque Head Bolts Procedure
I just replaced the head gaskets on my supercharged LT-1 (installed Cometic MLS gaskets). The car has been through a heat cycle and I am ready to re-torque the head bolts (per Cometic guidance).
I am going to unbolt the front brackets (supercharger and power steering brackets), but should I drain the coolant and / or remove the intake? Any other procedures that people use?
Thanks, Andy.
Old Jan 14, 2008 | 10:08 PM
Johns87's Avatar
Johns87
No,
You don't need to do either. You probably should loosen the intake bolts some and retorque them after doing the heads, but you don't need to remove the intake.
You shouldn't have to drain the coolant. The gaskets SHOULD keep that sealed during the retorque. It would not hurt in the least to drain and then replace the coolant, though.
From the post I get the impression that you are familiar with your gasket manufacturers retorque directions. If not, a standard procedure is to break all the head bolts loose and then retorque to a low level first(following the torque seq. pattern), Torque a middle step(in pattern) and final torque to spec(by pattern). If single-use torque to yield bolts, I think you just retorque to spec(by pattern) without breaking loose. Then you can retorque the intake.
I hope this is helpful, Take Care and Be Safe, -John
Old Jan 14, 2008 | 11:08 PM
F1Fan's Avatar
F1Fan
This is from their catalog for the MLS gaskets
"The composition of MLS will also withstand the shearing forces created by aluminum heads on cast iron blocks. No re-torque is necessary."
Are they suggesting that to you because of the supercharger?
Old Jan 15, 2008 | 08:51 AM
djxib's Avatar
djxib
I just read back through my notes, and I think the re-torque guidance (from the tech I spoke to at Cometic) was because I installed new ARP head bolts.
Old Jan 15, 2008 | 09:47 AM
F1Fan's Avatar
F1Fan
Hmm, thanks for the follow up, I guess I'm going to call them too.
I'm also using new ARP bolts and almost a 12:1 CR.
Old Jan 16, 2008 | 02:20 PM
Scandalous's Avatar
Scandalous
Hmm, this doesn't make sense to me. I am also using Cometic MLS on my 383 rebuild (with 11.4 C/R). I'm going to be fastening the heads in a day or two.
As for retorquing with MLS gaskets... I can't see why you would need to. The gaskets are steel shims, that's it! If you are using a fiber-based gasket (i.e. Felpro) then it would make sense to retorque after several heat cycles.
Looks like I'll be making a call to Cometic also...
-Justin
Old Jan 16, 2008 | 03:06 PM
djxib's Avatar
djxib
I dont think its anything to do with the gasket, but everything to do with the bolts.
After a full (30 minute) heat cycle on Sunday, I spent the effort on Monday to re-torque the passenger side head bolts and on average it felt that it took only about 30 ft-lbs to break the bolts loose. I eyeballed a few bolts and they turned an extra 20-30 degrees further clockwise from the original Torqued position.
During the build I used new ARP bolts, ARP assembly lube on the tops of the bolts, ARP assembly lube on the threads of non-water jacket bolts and ARP thread sealant on the threads of the water jacket bolts.
May just be my build, but after this experience I may actually re-torque the bolts again after I have put about 500-1000 miles on the car (and before race season officially starts).
Comments welcome!
To Re-Torque Head Bolts Procedure
