383-what oilpan?
Old Jan 14, 2008 | 11:12 PM
xrcrx's Avatar
xrcrx
Default 383-what oilpan?
2 pc rear main,383. Any recommendations for an oil pan that will go on a daily driver?
Old Jan 15, 2008 | 03:39 AM
emo-vet's Avatar
emo-vet
i more a less asked the same question earlier on today btw.
not much info or reccomendations besides kindly from rodj and larry
oh well.
shae
Old Jan 15, 2008 | 03:50 AM
xrcrx's Avatar
xrcrx
I ordered a pan from JEGS but it didn't fit. Talked to the folks at JEGS and Summit and basically their suppliers don't give enough info for them to know what will fit the Vette.
Old Jan 15, 2008 | 08:14 AM
LTxDave's Avatar
LTxDave
I have a custom pan from Exotic Muscle for my 383. The other option I think will fit is a Canton pan. Not sure you can get the canton pan in a 2 piece rear main seal, but the one from Exotic Muscle shouldn't be a problem since it was built to order.
Old Jan 15, 2008 | 09:28 AM
Muffin's Avatar
Muffin
Why are you changing the pan? Assuming you are building your engine the pan you have will do just fine for a DD. If you plan on racing or X-crossing with hi-G turns a change is in order.
Old Jan 15, 2008 | 11:30 AM
F1Fan's Avatar
F1Fan
You may be able to take a hammer and clearance your stock one.
Are both the rods and the pickup in the way?
Old Jan 15, 2008 | 07:28 PM
lead foot 85 vet's Avatar
lead foot 85 vet
I didn't know there was a differrance..........mine leaks a drop or two ....whats the differrance ?.... it's a 2 piece main......the shop changed the gasket 5 times...still leaks..............and for sale
Old Jan 15, 2008 | 09:12 PM
vetteset8087's Avatar
vetteset8087
I have built 2- 383's with 1 piece rear seal for my 87 on the first one with 5.75 rods I used the pan that came with my 87. the second one is a four bolt main roller block 1 piece rear seal out of a 93 4x4 truck I used the oil pan that came with the core motor out of the truck. this one I had to paint the inside of the pan roll the motor over to scratch the paint and clearance the obstruction with a ball peen hammer a couple taps with a hammer did the job. this was probably because I used a 6" I beam rod and not the stockers.
Old Jan 15, 2008 | 09:13 PM
soultkr96's Avatar
soultkr96
any small block oil pan for a two piece rear main seal will work. no matter what the name brand is
Old Jan 15, 2008 | 10:00 PM
calpbs's Avatar
calpbs
I have built about 10 stroker motors in the last year. I have used everything from a stock pan to drag pans to aluminum pans. I have built as big as 427 cu in. I typically just clearance with a ballpeen hammer. The aluminum pan didnt clearance as well but I made it work. Bottom line is you will have to clearence any pan you use. The nice thing about a C4 is virtually all pans fit.
Old Jan 16, 2008 | 09:54 AM
LTxDave's Avatar
LTxDave
Didn't have to clearance my aftermarket pan for my 383.
Old Jan 16, 2008 | 03:05 PM
xrcrx's Avatar
xrcrx
Moroso 20171 5qt, clearanced for up to 3.800", i'll let ya know how it goes.
Old Jan 16, 2008 | 03:45 PM
sprtsfn555's Avatar
sprtsfn555
Default oil pan
i bought a 7 quart oil pan from canton racing no problems on my 383
Old Jan 17, 2008 | 04:13 PM
xrcrx's Avatar
xrcrx
I talked to the guys at Canton. I wouldn't hesitate to deal with them-very helpful. Unfortunately they were outta pans that'd work for me till mid Feb or so.
To 383-what oilpan?
