Which Block, Heads, etc.
I am thinking of starting an engine build for my 85 coupe.
I want to build an engine that makes use of a centrifugal supercharger so I know I'll have to make a strong bottom end with some forged parts.
I'd be interested in the opinions of the experienced members as to which block, heads, and such to use.
Personally I have no problem with a forged rotating assembly from Eagle. The block will depend on how much power you plan to make. If you want under 500 HP, you could probably get away with a cast crank and I beam rods with forged pistons. But for anything above that, I'd go with forged crank and good forged h-beam rods.
