security system remote help
Old Jan 15, 2008 | 05:41 PM
Overboost's Avatar
Overboost
From: Flint Michigan, #2 in unemployment, #3 in Violent crimes
Default security system remote help
I have a 95 base and I would like to know how to find out if it is equipped with the security system remote. when I bought it it did not come with any and only 1 set of keys.
it has a light in the lower left dash that blinks "SECURITY" when you shut it off or open the door. I would like to know how to test it to see if it has keyless entry or did they all have it?
Old Jan 15, 2008 | 06:24 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Yes, your '95 left the factory with Passive Keyless Entry.
The "security" has nothing to do with the remote keyless option. Your alarm is still armed if you manually lock your doors when you get out.
To test if the alarm is working:
1. Roll down drivers side window
2. Open drivers door.
3. Press the door lock button to lock the door
4. Close the door.
5. Reach through open window and press door unlock button
6. Open door
Horn should start beeping! This is your alarm
To silence alarm, put key in door lock and unlock with the key.
To prevent alarm from going off, unlock the door in the following way:
1. With keyfob (which you say you don't have)
2. Put key in door and turn to unlock.
Old Jan 15, 2008 | 07:36 PM
Overboost's Avatar
Overboost
excellent, I will buy the key fob's I need ($160 online, yikes)
I just didnt want to spend the cash if I didnt have the keyless entry system.
Old Jan 15, 2008 | 08:08 PM
RollaMo-LT4
Do some research before you buy the FOB.
You may not like the way the system was designed to work. They are not like a regular FOB where you push the button to lock and unlock the door.
They are "passive", meaning your locks will lock and/or unlock as you approach and/or leave the vehicle.
Some people just don't like the way they were designed to work, and think the system is broken.
You can find the FOB's on ebay from time to time too.
To security system remote help
