Bonehead move, is Opti a ruined?
Old Jan 15, 2008 | 11:27 PM
Binski's Avatar
Binski
Default Bonehead move, is Opti a ruined?
I have had a 93 L11 for about 4 months with 97K miles. I have been slowly be going through it doing shocks, brakes, plugs,etc. I noticed that previous owner put window wash in the coolant reservoir, so I took it to a local shop to have it flushed. After I got home I noticed it was running a little hot, I called the mechanic and he did not bleed the water pump or the throttle body. I let it cool down and cracked the the bleeders. One of the bleeders was fine the other must have had some air, unfortunately I unscrewed the bleeder too far and screw fell down into the water pump. Just as that happened anti-freeze started to flow out of the bleeder. By the time I retreived the screw, I lost about a 1/2 gallon and it flowed all over the OPTI.
Do I bite the bullet and replace the Opti or refill and hope that the Opti will be OK. thanks for the advice.
Old Jan 15, 2008 | 11:35 PM
Digital Disaster's Avatar
Digital Disaster
Refill and hope all is well.
My '92 Opti got wet many times with no ill effects.
Good luck!
Old Jan 16, 2008 | 12:31 AM
WickedVetteLT4's Avatar
WickedVetteLT4
I say refill and hope its ok.
At worst, your gonna have to replace it anyway but if you dont HAVE to replace it, dont throw your money away.
Old Jan 16, 2008 | 12:46 AM
psychodiagnostik's Avatar
psychodiagnostik
I would drive it as long as it drives OK. I just finished replacing my opti after a coolant hose burst and messed it up, and it was a hard job for me. It's expensive too if you have a shop do it. I wouldn't mess with replacing it or having it replaced unless it was a sure thing that it was messed up.
I looked at the new one before installing, they actually seem like they're fairly water-resistant. I think chronic conditions that make them stay wet (like a leaking water pump) are the reason for most of the moisture-related failures you hear about, but I don't blame you for worrying.
I hope it's OK!
Old Jan 16, 2008 | 12:53 AM
Binski's Avatar
Binski
Thanks for the advice. I will fill it tomorrow and let you know. Thanks again.
Old Jan 16, 2008 | 06:40 AM
GS4-LT1's Avatar
GS4-LT1
I hope it's OK!
Old Jan 16, 2008 | 12:06 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I hope you don't have the Optispark Blues....
Old Jan 16, 2008 | 10:29 PM
Binski's Avatar
Binski
Default Update on Opti !
All is well. The Opti does not seem to have been affected by its little anti-freeze shower. Thanks for the advice!
Old Jan 17, 2008 | 09:42 AM
9secondflat's Avatar
9secondflat
that hack mechanic and his shop owner are 100% responsible for their screw ups...any decent shop will make it right.
Old Jan 18, 2008 | 08:49 AM
Dudeurgettnavette's Avatar
Dudeurgettnavette
Good luck!
Old Jan 18, 2008 | 08:58 AM
Powersmokin's Avatar
Powersmokin
just let it dry out.
Old Jan 18, 2008 | 10:18 AM
stranded's Avatar
stranded
To Bonehead move, is Opti a ruined?
