what gas to run
Old Jan 16, 2008 | 03:21 PM
defo98's Avatar
defo98
Default what gas to run
Do you guys think its alright to run regular in an 84 vette with 40,000 miles? I just dont know if regular is to bad of a fuel for a vette.
Old Jan 16, 2008 | 03:34 PM
GIMMESOME's Avatar
GIMMESOME
Yes.
Old Jan 16, 2008 | 03:35 PM
StealthLT4's Avatar
StealthLT4
unless you have an exotic car (not normal Corvettes), run the lowest grade gas you can. If it knocks, then move up to the next level. Sometimes gunk buildup on the heads and valves will increase the compression ratio, causing you to need higher octane gas. But an engine in good condition should be fine with 87.
Old Jan 16, 2008 | 06:52 PM
WW7's Avatar
WW7
Let the tank get almost empty then get a half tank of regular and see how she runs.
Old Jan 16, 2008 | 07:04 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Thats a L83. Regular will do. I visited the East Coast last year and most of the members here love to talk about Sunoco Gas. I tried and Yes, that has been the best gas in my Vette. Too bad they don't have Sunoco in California.
Old Jan 16, 2008 | 10:22 PM
black88z51's Avatar
black88z51
my 84 knocked unless I used premium fuel
Old Jan 16, 2008 | 11:24 PM
John A. Marker's Avatar
John A. Marker
I run regular 87 grade in my 1985 without any problems. You should be fine.....
Old Jan 16, 2008 | 11:26 PM
Demonic85's Avatar
Demonic85
If your car is completely stock...
'84-E86 (irons heads) 87 octane is just fine
L86-'91 (alum heads) use 89 or 91, might be fine on 87
'93 and up use premium
Of course mods, especially better heads, will change the scenario and you might need to go up.
Old Jan 17, 2008 | 02:21 AM
GS4-LT1's Avatar
GS4-LT1
As long as you don't hear any pinging noise when under throttle or going up a steep hill, a good quality 87 octane will be fine.
Old Jan 17, 2008 | 12:44 PM
Aurora40's Avatar
Aurora40
If you can put a scan tool on the car, though, you can check for knock retard at large throttle opening. If there isn't any, the octane is enough. My two cents, if you use regular gas, get it from a top tier company as 87 octane from a lot of places has very little in the way of detergents or additives.
To what gas to run
