Car is misfiring while accelerating ??
Old Jan 17, 2008 | 07:36 AM
Big Rat 427's Avatar
Big Rat 427
Default Car is misfiring while accelerating ??
Car just started doing this. Car runs fine at cruising and idling, just when depressing the gas pedal, it stumbles and misses trying to accel.
Before I start digging into it, what are common problems I should look to first. Car is an 85 with 101k miles on it. Thanks.
Old Jan 17, 2008 | 11:07 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Fuel filter, fuel pressure, distributer/igniton module.
Old Jan 17, 2008 | 11:24 AM
rick lambert's Avatar
rick lambert
Could be a ton of things, needs a tune up including new wires, dirty TB, TPS on the way out. Do you have the FSM? Things listed above. Mine turned out to be a bad injector pig tail. I doubt it's the ignition module though, if they're on the way out they usually make the engine run crappy (or not at all) in all RPM ranges as soon as they get hot.
Tools needed.
Fuel pressure guage
Digital Voltage ohm meter
Noid light.
Old Jan 17, 2008 | 01:12 PM
staugur's Avatar
staugur
Mine started to miss quite badly at WOT above 4000rpm.At partial throttle openings it would rev to 5000 with no miss!It had an expensive DYNA_MOD high performance module in there.Changed it for a cheap NAPA unit,no more miss.
Old Jan 17, 2008 | 01:32 PM
JackDidley's Avatar
JackDidley
Plug wires fixed mine, back in the fall.
Old Jan 17, 2008 | 03:34 PM
Demonic85's Avatar
Demonic85
sounds like they're toast. If that doesnt fix it i'd check out the MAF system. On my '85 the MAF module had a few broken solder joints and caused it to misfire. Easy fix if you can get it out of there without too much hassle. Replace the spark plug wires first though, probably burned up.
Old Jan 17, 2008 | 11:45 PM
u c brother's Avatar
u c brother
Plugs and wires.
Old Jan 17, 2008 | 11:52 PM
Siveck's Avatar
Siveck
The EGR can cause the stumbling or rather bucking. Temporarily unplug the vacuum line (plug end of line so there is no leak) and go for a ride. See if anything changes.
Old Jan 18, 2008 | 09:38 AM
Big Rat 427
Update, I think it was just a bad tank of gas. Used an off brand from normal, and it started with 12 hours after fill up, had tried Dry Gas to the tank immediatley when it acted up, but didn;t help any at that time. On the way home last night I was down to about half a tank and topped off with my normal station with the 94 I usually run. byt the time I got home it was clearing itself up. Hope thats all it was.
Here is a question thou, if an 85 had a misfire, would the check engine light come one. New cars, 96 and newer with the OBDII computer will lgiht immediatley and stay lit and stored. My light never came on, but not sure on the 85 technology for diagnostics.
Old Jan 18, 2008 | 09:47 AM
JackDidley's Avatar
JackDidley
No check engine light will show up for a miss on a car as old as ours. The electronics are just too primative.
Old Jan 19, 2008 | 04:53 AM
85L98-84L83's Avatar
85L98-84L83
Originally Posted by c my taillight
Plugs and wires.
To Car is misfiring while accelerating ??
