fuel lines
Old Jan 17, 2008 | 08:03 AM
19vette89's Avatar
19vette89
Default fuel lines
does anyone know who makes a premade fuel line that runs from the top of the fuel filter to the front of the fuel rail, or does anyone have one for sale? it is for an 89 vette(coupe). the nut is rounded off on mine and i can't get it loose from the filter!
Old Jan 19, 2008 | 12:05 AM
carson's Avatar
carson
Ran across these fitting.
http://cgi.ebay.com/ebaymotors/AN-6-...spagenameZWDVW
With these you can use braided hose, make the hose yourself or get it pre made.
Old Jan 19, 2008 | 03:55 AM
RRT vette's Avatar
RRT vette
Just so your aware, there are different sizes fittings at the fuel rail over the years. Mine had a bad leak in the rubber hose and I purchased a used set from the same year. I called around all over the US and the prices ranged from $100-200 for a set of used lines. A 91 nor a 89 would fit my 86 fuel rail.
Old Jan 19, 2008 | 09:57 AM
89corvetteken's Avatar
89corvetteken
Which line are you looking for,the one with the pulse dampener (I believe the return) or the one without.
I may have what you need.
Old Jan 20, 2008 | 12:08 PM
ukzo6vette's Avatar
ukzo6vette
Default Fuel Lines
Take a look at this company website, may be of help to you:
purechoicemotorsports.com
Old Jan 20, 2008 | 03:27 PM
Razor89's Avatar
Razor89
Thanks for the web site suggestion!
Old Feb 1, 2008 | 09:27 AM
19vette89's Avatar
19vette89
i'm looking for the piece of fuel line that runs from the top of the filter to the throttle body. before it goes into the throttle body, the line almost makes a 90 degree turn.
To fuel lines
