do you get a vacuum with boost?
Old Jan 17, 2008 | 08:05 PM
Slinky85's Avatar
Slinky85
Default do you get a vacuum with boost?
When you blow or boost a car, do the vacuum lines still have vacuum? is it necessary to get an electric vacuum, to retain stock vac. components? which is a better system for handling a boosted car, MAF or MAP?
Old Jan 18, 2008 | 12:41 AM
Mo_Bandy's Avatar
Mo_Bandy
The vacuum lines stay vacuum until you go into boost. It is not necessary to go with a vacuum pump unless you have a cam where you are runnig extremely low vaccum at idle.
I'm running power brakes with no issue...
There are alot of us running both MAF and MAP systems... I would say thet they are pretty much equal in trying to tune them...
Hope this helps!
MO
