84 4+3
Old Jan 17, 2008 | 08:18 PM
pappyfreebird's Avatar
pappyfreebird
Default 84 4+3
shifts fine and od fine too...but if let off gas in 3rd can feel shifter jumping ...wont pop out of gear but harder let off harder can feel it...will it last just to run it (now that know this)?? and is it like a bent or wore fork??? thanks
Old Jan 19, 2008 | 03:30 PM
pappyfreebird
i know ive read the same somewhere...anybody??
Old Jan 20, 2008 | 12:37 PM
Yellow2015's Avatar
Yellow2015
Could you clarify what's in bold type? Harder to let off harder?
Old Jan 20, 2008 | 01:37 PM
c4cruiser's Avatar
c4cruiser
The shifter mechanism is attached to the body, not the tranny. You might check to see if the assembly is attached tightly.
Also check the rods to make sure they are secure and there is no slop in the holes on the shifter arms or on the arms on the tranny.
Old Jan 20, 2008 | 02:41 PM
pappyfreebird
thanks c4 i hafta check it out
ny i mean higher rpm let off ...the more quiver i feel in shift lever...let off low rpm and no quiver higher the rpm the more the shakes...sure hope its jus loose ive heard and read this thanks fellas pappy
To 84 4+3
