A friend (yes, it's not me) has a '91 very tired vert and has the opportunity to purchase a low mileage LT4 for a reasonable price. I've tried to locate info on this conversion with no luck.
Has anyone done this out there that might shed some light on what would be expected with this? I know that's a very general question, but I'm thinking there has to be an archived thread out there somewhere with detail. Any leads would be greatly appreciated.
Well the easiest way to do it would most likely be to machine the LT4 intake to accept a distributor and use the L98 distributor in the LT4 car. GM makes a block off plate for the timing cover on the LTx engines so they can be used with a distributor in carbed applications. The rest would be connecting fuel lines, getting it tuned, making sure the water pump inlet and outlet go to the correct sides of the radiator, and I suppose using the LT4 accessory bracket and accessories. Starting to sound like a PITA to me. I'd just build the L98 with a miniram and a good set of AFR heads.
I would think he could leave the opti on rather than going back to the L98 distributor. Or am I missing something?
What I'm talking about is pulling the L98 out and dropping in a complete LT4. I'm looking for inconsistancies that might occur in electronics, sensors, etc. I'm sure fitting won't be a problem, it's the same body as my '93 w/ an LT1.
I'm saying to keep the L98 distributor in order to keep the factory wiring harness in tact. If you want to swap wiring harnesses and everything, leave the Optispark. Seems easier just to build a better engine out of the L98 for the money spent on the conversion.
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
big up with pickers to use a caprice lt1/ HEI/ l98 ecm (they abhore the opti due to cost and off-road unsuitability) in their toys...several locals have done it and obviously ''rocket science'' is not involved...check the truck forums for info.
Corvette Fever did an article on that and it cost about $11,000 to switch it over properly. Why not just buy a 96 with the LT4, will cost the same or less. Don't destroy a L98 rebuild it L98s rock
