do you get a vacuum with boost?
Old Jan 17, 2008 | 08:55 PM
Slinky85's Avatar
Slinky85
Default do you get a vacuum with boost?
When you blow or boost a car, do the vacuum lines still have vacuum? is it necessary to get an electric vacuum, to retain stock vac. components? which is a better system for handling a boosted car, MAF or MAP?
Old Jan 17, 2008 | 10:22 PM
AKS Racing's Avatar
AKS Racing
Boosted cars still have vacuum when at idle and under part throttle. Basically, vacuum is anywhere from idle to WOT (0 - <14.7 psia) before the vacuum disapates. Then there is a period at WOT where there is no vacuum and no boost (14.7 psia). This is followed by boost (>14.7 psia).
The requirement for a suplemental vacuum pump will depend on cam and other engine components, but I would highly doubt that one would be required for the builds on these boards. I run a large solid roller and the car still pulls ~14"Hg at idle and cruising will pull in excess of 18" Hg. This is sufficient for power brakes, etc.
MAF or MAP? Depends on whether it is a stock or aftermarket ECM. Stock ECM and fairly mild build, I find that MAF is the better route. Highly modified combo, and an aftermarket ECM, certainly MAP is the route to take.
Aaron
Old Jan 18, 2008 | 12:44 AM
Mo_Bandy's Avatar
Mo_Bandy
there are two posts ...
MO
Old Jan 18, 2008 | 05:14 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Hey Guys,
Aaron's explanation of the transistion from vacuum to boost is perfect. Let me add that the vehicle's HVAC controls are fed from a vacuum cannister. The vacuum cannister connection to the intake manifold is thru a checkvalve. The idea is that at WOT (with or without a blower or turbo) the HVAC vacuum actuated 'doors' continue to operate. Without the checkvalve the 'doors' would return to their resting position while accelerating. So with or without a blower it's a good idea to verify the operation of the checkvalve and vacuum cannister. 20 year rubber tubing may need replacing and make sure no one has removed or by-passed the GM checkvalve.
The brake booster also has a checkvalve which should be checked and sometimes I add an in-line heavy duty checkvalve to protect the booster with high boost applications. Remember while braking your foot is typically off the throttle anyway providing maximum vacuum. So even with a big cam there is plenty of vacuum while the engine is deaccelerating.
Best regards, Greg
To do you get a vacuum with boost?
