Re programming the computer
Old Nov 29, 2001 | 07:48 PM
TypeR's Avatar
TypeR
Default Re programming the computer
"New to this"
whats the best way to do this ? I've seen a lot of different programming devices for sale. and what about a chip?
Old Nov 29, 2001 | 08:18 PM
Jimmy69's Avatar
Jimmy69
Default Re: Re programming the computer (TypeR)
The PCM in your 95 is FLASH based, so no chip burning is required. There are two software packages available:
LT1-Edit : http://www.carputing.com
TunerCat: http://www.tunercat.com
You will also need a PC (Laptop perfered), and a ALDL cable (allows the PC to interface with the PCM). You can build the cable yourself, or purchase it from http://www.wotelectronics.com/cables.html
Jimmy
Old Nov 29, 2001 | 08:24 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Re programming the computer (Jimmy69)
You can also use Hypertech Power Programmer which is MUCH easier, but also limited on what you can do
Old Dec 1, 2001 | 12:30 PM
KORE YOME's Avatar
KORE YOME
Generic chips and Hypertechs are a joke. They can't adjust anything or are extremely limited in what they can. I returned my HYP to summit after major disappointments (and I never even installed the "engine tuning" part of it either!) I use the LT1_edit software from carputing. It's great and worth every penny that I saved because it was cheaper than the hypertech. Reprogramming with the software is simple to do, but make sure you read EVERYTHING on the web page before you buy/program. I have no complaints and have reprogrammed my car about 50 times now with no problems. Customer service is excellent too.
To Re programming the computer
