I'm running around 12-15 lbs boost on the vortech setup and was wondering if i need to replace the bypass valve that came stock with the kit. I don't think the valve is staying closed under boost.....and causing me to only see around 10-11lbs. I know it can and will do more because it did when i got the car back with the motor rebuild in it. Any clues or suggestions?
I have seen people change them to the "HKS Bypass valve." are these better than stock?
I run a different set-up (twin Vortech Mondo Race valves), to allow the SC ducting to stay together and to keep from "hanging the MB throttle" between gear changes. 2300CFM will blow connectors apart regularly and will allow you to keep accelerating when you really don't want to.
Aaron
ok so if its not the bypass valve not closing...what are some possibilities for the boost decrease? I do note some belt slipage. also would there be a gain from a 48 to 58mm tb or a larger mass air flow sensor with a supercharged setup? thanks for any input
If you are still running the cheap plastic bosch bypass valve that comes stock with your kit this may indeed be your problem. I have seen them start bleeding boost above 10#. It's just not what they were really intended for. If you do infact have one of the better Vortech (aluminum bodied valves) it's probably something else unless yours just happens to be faulty.
