Help! 89 Cluster Instant Fuel/Avg Doesn't work
Old Jan 22, 2008 | 04:39 PM
ghbrothers's Avatar
ghbrothers
Default Help! 89 Cluster Instant Fuel/Avg Doesn't work
I have an intermittent instant fuel/avg fuel issue ... once in a great while it works. I just got the cluster back from a rebuild shop and all checked out fine. I have checked and rechecked connections. What am i missing? Could it be a bad data channel in my ECM? Thanks for any help you can forward.
Old Jan 22, 2008 | 05:54 PM
SunCr's Avatar
SunCr
Cluster circuit is spliced into the Diagnostic Link from the ECM. Ground the Link and see if it Flashes a Code 12. Generally if there's a Code 12, ECM, and wiring are ok - something is going on between the splice and the Cluster or it's the Cluster. If there's no 12, it's the wiring or the ECM.
Old Jan 22, 2008 | 06:28 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
At least it's the least important feature on the car!
Old Jan 22, 2008 | 07:22 PM
SunCr's Avatar
SunCr
Considering it's a splice from the Diagnostic Link, I don't know how you would consider it unimportant. If it isn't the Cluster, it's allmost always the ECM or wiring. I wouldn't want to run around on backup or have to try to diagnose a driveability issue without being able to hookup a Scanner.
Old Jan 22, 2008 | 07:34 PM
Yellow2015's Avatar
Yellow2015
Wouldn't that affect your "range" as well? Is the information accurate when it's working or is it just an intermittent off condition?
Old Jan 22, 2008 | 08:13 PM
BADDUCK's Avatar
BADDUCK
I don't know HOW we got by all those years without knowing our "instant fuel mileage".
To Help! 89 Cluster Instant Fuel/Avg Doesn't work
