Engine oil temp...
Old Jan 23, 2008 | 12:57 PM
amm0bob's Avatar
amm0bob
From: The last place on earth to get cable... Sacramento
Default Engine oil temp...
I noticed that my engine oil temp is running about 250 while the coolant temp is around 170-180...
I didn't ever see the oil temp that high during the summers or last winter for that matter... is this something I need to look into... and what could it be.
Thanks in advance.
Bob Jr
Old Jan 23, 2008 | 01:00 PM
vader86's Avatar
vader86
Sounds like the oil temp sensor is bad. There wont be such a dramatic gradient between the two temperatures.
Old Jan 23, 2008 | 09:11 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Oil Temp
make sure there's enough oil in it.
If you have the optional oil filter/cooler, it's your sender.
Old Jan 23, 2008 | 10:26 PM
bczee's Avatar
bczee
Usually you have a 15-30 differents. 70-80 is way off. Check that sender or even the guage.
To Engine oil temp...
