racetronix fuel pump..same install as stock?
Old Jan 23, 2008 | 05:41 PM
finally_got_it's Avatar
finally_got_it
Default racetronix fuel pump..same install as stock?
i just got my racetronix fp in and there were no instructions, is it the same procedure as stock? Any install tips would be appreciated
-Chris
Old Jan 23, 2008 | 06:27 PM
JackDidley's Avatar
JackDidley
The one for my 87 was plug and play. 30 minute job and did not break a sweat. I have heard there may be a wire terminal to mod on some of them though. Did you look on the website for instructions??
Old Jan 23, 2008 | 06:30 PM
finally_got_it
yes, i looked and could not find instructions anywhere well i guess ill start the removal and hopefully someone will chime in by the time im ready for re-install
Old Jan 23, 2008 | 07:35 PM
DVNCI's Avatar
DVNCI
Go here:
http://www.blowerworks.net/
Click the downloads link on left.
Scroll down and you'll see the "Corvette 1989 thru 1996 GSS 340 In-tank Fuel Pump Installation Guide"
It's really good, this is what I used a while back.
Spankyellow - you are correct, there is a slight wire mod.
Old Jan 23, 2008 | 09:01 PM
jeffyc's Avatar
jeffyc
on my 91 i had to do some modifying (cut and solder)
Old Jan 23, 2008 | 11:27 PM
Kool88vette's Avatar
Kool88vette
I just had to modify the eletrical connectors. The job takes about an hour.
Old Jan 24, 2008 | 12:21 AM
finally_got_it
its in and done! i only had to remove it 2x cuz i put the float in wrong , but one more lesson in the books, and more knowledge gained!
-Chris
Old Jan 24, 2008 | 01:27 PM
STL94LT1's Avatar
STL94LT1
Any electrical splicing, or was it "plug and play"?
Old Jan 24, 2008 | 01:35 PM
finally_got_it
nah, just unplug old wiring and replace with new! hardest part was remocing the fuel lines..those dudes did not want to come off, although my skin sure came off persuading the hoses
To racetronix fuel pump..same install as stock?
