K&N Air filter......
Old Jan 24, 2008 | 07:03 PM
Weav's Vet's Avatar
Weav's Vet
Default K&N Air filter......
I have one coming tomorrow hopefully. But in advance of its arrival I went ahead and cut out the louvers in the lid. My question is.......Was I supposed to remove the rain shield? I did remove it. Shouldn't be a lot of trouble to reinstall if need be. I try not to drive in the rain but sometimes it happens. Should I reinstall the shield or does it even matter? Now I know the big debate over these these filters. Performance wise not much help. But on Vader's site he said if you don't think it is not a better filter just check it after 10K miles and see what it trapped.
Old Jan 24, 2008 | 07:17 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I would leave the shield in.
Old Jan 25, 2008 | 03:16 AM
85 500 horse's Avatar
85 500 horse
It's there for a reason. Cutting out the louvers was a good step to increase the airflow. The HP increase of the K&N comes into play when you have done other mods. If the installation of the K&N is your only mod so far, you will not see any difference whatsoever. But that's okay. You gotta start somewhere, right? Do the little things and then work up to the bigger ones. Just don't throw in an airfoil. You'd be better off writing me a check.
Old Jan 25, 2008 | 04:48 AM
Weav's Vet's Avatar
Weav's Vet
I guess my logic behind this was.......the replacement filter frame that K&N sells along with this filter appears to have have no louvers. So I improvised to save a buck. Also, it was time for a new filter so I figued I'd make it a one time thing with the K&N. Don't worry....NO airfoil. Edelbrock makes a 52mm TB that has one built in. Any thoughts on that? I'm not planning any major engine work here. Just trying to maximise what I have already. Thanks 85
Old Jan 25, 2008 | 05:19 AM
RRT vette's Avatar
RRT vette
The only reason I went with a K&N is so I don't have to buy air filters every so often. Like 85 500 horse said, you want see any gains until more modifications are done to pull more air into the engine. I wouldn't worry with a 52mm tb, the stock one flows more than enough air on the stock TPI. Spend that couple hundred dollars on roller rockers or exhaust...all depending on what is already done to the engine.
wilsonbh's Avatar
wilsonbh
OK, I'm an idiot...I don't understand what you mean here.
Can someone post a picture of what the end result looks like when you say "cutting out the louvers." I have a K&N filter. I just replaced my paper filter with the K&N and did nothing else. Put all the plastic back together and that was it. What else would have been better to do?
Billy
Old Jan 25, 2008 | 05:48 AM
Weav's Vet's Avatar
Weav's Vet
Billy
No pics but it is a series of sloped slats in front of the filter on my 96 and it's metal not plastic. I just used snips ro remove them to enlarge the opening more. Design change from the '94 you have I guess.
Mid America has pictures of the filter and frame from K&N. You'll notice in them that the whole face of the filter is exposed.
Old Jan 25, 2008 | 01:13 PM
85 500 horse
As mentioned, I wouldn't switch to a 52 mm TB until you do other mods. You won't see a performance difference until you do other things; such as free flowing exhaust and cat(s), headers, better heads, roller rockers, etc.
Old Jan 25, 2008 | 01:36 PM
BADDUCK's Avatar
BADDUCK
I agree. A 52mm throttle body will not help until you add way more HP. Spend the money on something else.
Old Jan 25, 2008 | 02:14 PM
Weav's Vet's Avatar
Weav's Vet
Ok, any suggestions? I know about the exhaust, high flow cats etc. Didn't think RR's accomplished a lot without a cam to go along with them. If i'm reading you guys correctly then........none of this bolt on stuff is worth a dime, right? Keep in mind as I mentioned before, not looking for some big increase in HP here. I understand what that involves and I won't be going there. I just want to maximise what is there already. It's already had a good tune up. Will having the ECM tuned by say, PCMFORLESS do any good?
Old Jan 25, 2008 | 02:53 PM
thor_258's Avatar
thor_258
Cruising
Default where should my money go
not meant to be the final answer but i did find this an interestin read and very relevant
http://www.corvettephotographs.com/c...erformance.htm
Old Jan 25, 2008 | 05:32 PM
BADDUCK's Avatar
BADDUCK
There is a current thread on Cheap/Free Mods read that. Best bang for bolt ons is exhaust. No need for custom ECM until you do heads, cam, etc.
LT headers, true duals, high flow cats will help.
Old Jan 25, 2008 | 05:42 PM
Strick's Avatar
Strick
Do yourself a favor and check your intake of the throttle body before you install the K&N. Then after a few thousand miles, check the intake again. You might be disappointed in what you see. There is a saying in the Corvette world that says,"Race with a K&N, but use the paper for daily driving"
Old Jan 25, 2008 | 06:23 PM
fnsblum's Avatar
fnsblum
Ditto Strick. Later! Frank
Old Jan 25, 2008 | 08:27 PM
MightyMike's Avatar
MightyMike
Guys,
Here is a pic of my recent install.
Old Jan 25, 2008 | 08:44 PM
GM Junkie's Avatar
GM Junkie
Old Jan 25, 2008 | 09:05 PM
RRT vette's Avatar
RRT vette
As far as a custom tune tune goes, you want gain much if any hp from it. It is a good thing, IMO, to have a custom tune so you can changed a few things. Fan on/off times, optimal timing, remove speed limiter, remove skip shift, remove VATS, remove EGR and AIR, changes in altitude A/F, ect. You might squeeze a little more out of a custom tune if you datalogged the PCM, but everything needs to be mechanically up to par.
For some reason I though this was a L98 car when I made my earlier post. :o
To K&N Air filter......
Old Jan 26, 2008 | 04:39 AM
Weav's Vet's Avatar
Weav's Vet
Almost seems like this should be the other way around in reguards to dust. The Road coarses I've seen in videos have more dust than I'll ever see on the highway. Perhaps you meant the 1/4 mile. And the K&N's have to be oiled or they are not very effective at all.
Anyway, thanks for all the opinions guys. Sounds like maybe I should just drive it and enjoy what I have and save the $$$ for another project. Also, maybe quit reading so much!
Old Jan 26, 2008 | 04:56 AM
RRT vette's Avatar
RRT vette
Hold a paper filter up to sunlight and then hold a K&N up to sunlight. You can see more though the K&N. I would think that smaller particles could get through the K&N that wouldn't the paper. Another thing about the K&N is not to apply too much oil on it. If too much, it can get on the MAF and into the throttle body/intake manifold. I always let mine sit longer than recommended after oiling.
Old Jan 26, 2008 | 09:48 AM
xflagz51's Avatar
xflagz51
Hey MightyMike,
Did you cut the original lid or is that one an aftermarket peice? Wish mine looked that clean.
Adam.
