Will an 85 ECM work in an 86?
Old Jan 25, 2008 | 07:50 PM
Chatman's Avatar
Chatman
Default Will an 85 ECM work in an 86?
OK. So I grabbed what I thought was a good deal without doing the research. I have in hand an 85 ECM and Prom for a 4+3 and an 86 car. My car is working fine, this was to be a spare or maybe a switchout because I thought that most of the "new" functions in 86 were things I would prefer to live without -- automatic overdrive shifts and VATS. So, how wrong was I?
P.S. If it is hopeless, there will be a reasonably priced ECM and PROM for a 4+3 in the parts for sale section.
TIA
Old Jan 25, 2008 | 09:10 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Do not use it. The 86 is a faster ECM and different attributes than the 85.
I do not know the specifics other than an 85 is NOT the same as an 86.
Old Jan 25, 2008 | 09:38 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
I think the difference is in the prom. That computer was used on several cars. The ECM's I think are pretty cheap at the local Autozone, or used to be.
Old Jan 25, 2008 | 10:21 PM
joeld's Avatar
joeld
That is correct, ECM replacement year numbers are 1986 thru 1989. Starting in 86 the ECM was updated for a much faster ECM. Sell it and cut your loss.
Joel
Old Jan 25, 2008 | 10:26 PM
mk842766's Avatar
mk842766
TIA
Nope, won't work...the connectors are different....if you want to get rid of the vats, and the overdrive shifts, get a burner, and take 'em out of your stock chip, and reburn it...
Old Jan 26, 2008 | 01:00 AM
RRT vette's Avatar
RRT vette
Not worth your effort or time to swap to repin the connectors.
Old Jan 26, 2008 | 07:39 PM
Muffin's Avatar
Muffin
Different animal. Big difference is in the MAF burn off. 85 triggers a module for burh off. 86 uses two relays.
To Will an 85 ECM work in an 86?
