Mini-Ram questions
Old Jan 25, 2008 | 08:55 PM
SCOTT J's Avatar
SCOTT J
7th Gear
Default Mini-Ram questions
So I just ordered my Mini-Ram, and fuel rail kit today. Here are my questions.
1. What do I do with the cold start injecter?
2. I've read on other posts something about a dead pin on the mas, what is that all about?
I'm getting rid of the air injection, getting long tubes, once the 383 is broken in. Any other advice is welcome.
Old Jan 25, 2008 | 09:34 PM
JackDidley's Avatar
JackDidley
You will need a new chip. The chip will be done with a differen tbin that eliminates the need for the cold start injector.
Whats a mas ??
Old Jan 26, 2008 | 12:04 AM
5speedC4's Avatar
5speedC4
I just installed my miniram. Got it finished today.
Cold start not used.
Don't know anything about the other.
It sure makes the L98 feel different.
Be sure not to let yourself rev to far.
I found that mine will go from the mid 5,500 rpm to over 6,000 rpms before you know it.
Be careful until you get a chip with a rev limiter.
Old Jan 26, 2008 | 05:47 PM
SCOTT J's Avatar
SCOTT J
7th Gear
Sorry, ment maf sensor.
Old Jan 26, 2008 | 06:26 PM
rodj's Avatar
rodj
Originally Posted by SCOTT J
Sorry, ment MAF sensor.
None of the electrics need changing with the intake swap.
Unless starting in really cold conditions the cold start is un needed , just tape up and hide the cold start plug.
To Mini-Ram questions
