Fuel Line Replacment.....HELP!!!
Old Jan 26, 2008 | 09:41 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Fuel Line Replacment.....HELP!!!
OK, I have to replace the fuel line from the filter mounted on the frame rail, to the throttle body .
I have a few questions:
1. Is the fitting on the filter something I can buy to adapt the new line or do I have to cut the line up stream and make an additional connection?
2. I expect that the fuel line is typically stainless steel...is it?
3. I think I am going with aluminum line like this:
http://store.summitracing.com/partde...0+115&autoview =sku
4. Then I can put ends on it like this:
5. Or should I use braided line like this:
http://store.summitracing.com/partde...+115&autoview= sku
6. With connectors like this
http://store.summitracing.com/partde...700+115&autovi ew=sku
I think the AL line is easier to deal with, more ridged, and will stay in place better. I have tubing cutters and all necessary tools.
The stock line is 3/8s. I am assuming it is stainless steel. Will these AL adapters work on SS?
http://store.summitracing.com/partde...0+115&autoview =sku\
My plan is to cut the 3/8 stock SS tubing behind the fuel filter. Put one of the adapters above on the 3/8SS.
Connect that with the AL tubing and run where necessary.
Once past the point of problem, repeat process on the other side of the fuel line.
I have to do both the feed and return.
Does anyone have any better suggestions?
The issue is that where the fuel lines pass between the headers and the frame is very tight and the fuel lines are too close to the headers.
TIA....
Old Jan 26, 2008 | 10:23 AM
evmlarry's Avatar
evmlarry
I know I've seen these sold individually, but you need something like this http://www.jegs.com/webapp/wcs/store...45157_-1_11175.
It'll take the fuel line fitting down from saginaw to AN.
Old Jan 26, 2008 | 10:50 AM
jsup's Avatar
jsup
Cool, those will work.
You need the old fuel line? I can't promise that it will come out in one piece...
Old Feb 1, 2008 | 09:14 AM
19vette89's Avatar
19vette89
what did you do with the old fuel line from the filter to the throttle body? was it still in good shape? was this on an L98 engine? i might be interested in buying it from you.???
Old Feb 1, 2008 | 10:25 AM
jsup's Avatar
jsup
Sorry, I cut it up.
What I did was use the stock ends, and stainless braided flex middle to re-route.
To Fuel Line Replacment.....HELP!!!
