Bose Speaker Replacement
Old Dec 1, 2001 | 01:40 AM
Benjamin Wagman's Avatar
Benjamin Wagman
Default Bose Speaker Replacement
Hello, I'm planning on replacing my four bose speakers. I have an 1989 corvette with a kenwood head unit. I would like to upgrade the speakers, but I know there can be a problem with the factory installed amp (I think) Can I simply purchase new speakers from another manufacturer like pioneer and plug them into the factory setup, or will I need to do any major modifications? Also what size are the factory bose speakers? Any help would be greatly appreciated in that I have removed the speakers and have no sound although the sound of my 383 is nice! Thanks,
Ben
Old Dec 1, 2001 | 01:47 AM
Kale's Avatar
Kale
Default Re: Bose Speaker Replacement (bwagman)
I just got done with this.
Let me tell you, I wouldn't do those doors again if I had to. As you can see.. all bose crap must be removed.
Old Dec 1, 2001 | 01:55 AM
Mr. CJ's Avatar
Mr. CJ
Cruise-In I Veteran
Cruise-In II Veteran
I always loved the Bose system. I've had some troubles, and maybe there are better systems out there. BUt if you remove the factory amps, you should be able to put in speakers of an aftermarket kind with little difficulty I would imagine. I've always been a stock interior person myself.
Old Dec 1, 2001 | 02:27 AM
apollo30346's Avatar
apollo30346
You can replace the rear with 6x9's and the dash is 4x6. I have a set of Pioneers 4x6 and a set of 6x9's that are a month old. I took back out to do a total custom system. If you are interested in them I would sell them for 100.00 shipped to you. They also have the plugs on all of them for a plug in install. E-mail me if you want to talk about them. They sounded great....Much better than the Bose.
Pete
Old Dec 1, 2001 | 11:00 AM
Benjamin Wagman
Default Re: Bose Speaker Replacement (Smash)
if I just removed the speakers, and put new ones in would I have to worry about the factory amp? Also the 6X9's you have in the rear, were there any modifications, because I know the rears are much smaller stock.
Thanks for the input
Ben
Old Dec 1, 2001 | 11:03 AM
Benjamin Wagman
Default Re: Bose Speaker Replacement (apollo30346)
I don't have speakers in the dash, was that an option. I have 1 speaker in each door and 2 speakers in the rear. Are the doors also 4X6? Thanks for your input, I have speakers waiting to be installed they are 6X9's, but thanks for the offer, it's a real great deal
Ben
Old Dec 1, 2001 | 12:07 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I'm a bit confused...nothin'new.. you have Bose speakers and a Kenwood head unit ???... everyone here says you cannot mix and match with Bose...whats up....
Old Dec 1, 2001 | 12:23 PM
TA's Avatar
TA
Default Re: Bose Speaker Replacement (golfboy1)
You can use an aftermarket head unit with the Blose system, but you need some type of an adaptor to make it work. I think you used to be able to get them at Wal-Mart for like 20$. I'm pretty sure they sell better (and more expensive) adaptors, but for 20$ I'd give it a try.
Old Dec 1, 2001 | 12:25 PM
Black 'n Blue's Avatar
Black 'n Blue
With the bose system, each speaker is housed inside its own amp. The speakers are all
3.5 inch(I think), but the amps themselves occupy most of the space. So if you remove
the speakers from a bose system, there is no factory amp remaining, and you will have to
find or make mounting plates for your new speakers. You will also need to purchase one or
more aftermarket amps to power them, unless your kenwood unit has built-in amplification--
but even if it does, even a cheap amp will probably sound better. Are you sure your speakers
are the factory originals?
Old Dec 1, 2001 | 12:40 PM
Benjamin Wagman
Default Re: Bose Speaker Replacement (Black 'n Blue)
I purchased the adapter (and yes it was at walmart for $20) The radio works fine, however, with no volume I still here some static. As far as the amps are concerned, I tried disconnecting them, plugged the speaker in and got no sound. So what I guess you're telling me is I have to purchase an amp to power the speakers? Can the amp be an after market? Also can I keep the front bose with the factory amp and use after market rears with an aftermarket amp. I don't have the time to change the fronts completely with amp. thanks for all who responded ASAP, that's why I love this forum....VERY HELPFUL!!!!
thanks again,
Ben
Old Dec 1, 2001 | 01:17 PM
BowTie C4's Avatar
BowTie C4
I dumped my complete Bose System. Kenwoos headunit, Eclispe EQ, amp mounted in the right side storage bin, eclipse speakers in the stock location, JL sub mounted over the ABS in the left side storage bin. :cool:
Old Dec 1, 2001 | 01:36 PM
Togo's Avatar
Togo
thats not true....as far as i can remember.....there is a problem with the power antenna switch that is not turning on your amps.....my deck does the same thing.....so guess what...BOSE is history!
there was an extra wire i had to put to always power on to get mine to work hence the whining noise even when the deck is turned off.....i wish i could remember what color it was....just turn the key on and probe the wires with a meter and do the same with the key off.....you will then find this mystery wire!
Old Dec 1, 2001 | 02:54 PM
Black 'n Blue
thanks again,
Ben
Yes, you can use an aftermarket amp with your rear speakers, and also still use the front
speakers as they are. You will probably have to play around with the balance a little to get
it to sound right, and you may end up running new wires from the head unit to your rear
amp.
Old Dec 1, 2001 | 03:09 PM
Kale's Avatar
Kale
The rear is built to take a 6x9. Ifr you dont have the bose, thats what is there. You must remove the bose amps, then build a mounting plate. you do have to cut your door panel to put 6.5's in though. it was worth it, much better than the crappy 4x6's i had up there first
Old Dec 1, 2001 | 03:20 PM
vms4evr's Avatar
vms4evr
I've been this route on an 84 I had for a while. The Bose receiver only has a pre-amp. The speakers have built-in amps, like 100watt each. I put a Kenwood head unit. There is a converter from Crutchfield that will let you use the factory speakers. We tried it, it sucked. I then went and replaced the speakers with some Boston Acoustics. Much better. On the early C4s the back speakers are 6x9s and easy to replace. The BA speakers ligned right up with the original plate so I just screwed them in and used the Bose covers. The doors were a bi$%& as most people noted. But we used the factory covers again.
On the later C4s, like my92, the back are 6" round and easy. The floor has 2 speakers. I beleive a 4 or 6" round and tweeter. Haven't ever taken them apart. On my92 I've kept the Bose and replaced the rear amps. If you replace amps do them in pairs. It makes a difference...
To Bose Speaker Replacement
