Hello everyone. My abs has recently stopped working, however, when I start the car I can hear the pump doing its little self check however it runs for a second or two compared to the quick little mmmmm normally heard. I have tried to bleed the brakes thinking there might be air in the lines but I was wondering if there could be air in the pump and if so how do i bleed it.
You say your ABS "stopped working." What are the indications or symptoms?
I guess I should explain a little more. Sorry I was at work and had to type in fast when backing down an inclined driveway the pump continues to run and i can feel the pedal moving. Also when i start the car instead of just hearing the normal short self test it normally runs it runs for a few seconds. The other day while I was driving down the street (after fixing the tranny) I decided to see if the abs worked. I was going about 50 and hit the brakes and the tires locked and slid until I released the brakes. thinking the lines or the pump may have air in it I bled the lines and everything appeared to be okay. So I was wondering if the pump can get air in it or also could it be a wheel speed sensor. If so how to do I tell which it is.
hmm....so now it looks like i get to take the center console apart to see why the lights are not coming on. hopefully the harness has just come loose or bulbs burned out.
