Ccm
Old Jan 29, 2008 | 01:54 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Ccm
I have a car that I am buying some parts off. The drivetrain is still good and the owner wants to retain anything related to the drivetrain so that he can crank the engine to show potential buyers that the engine starts and properly operates. I have been obtaining interior parts and the like. If I remove the CCM will the engine still crank and idle? Will remove the PKE have any ill effect on the car?
Old Jan 29, 2008 | 05:00 PM
RRT vette's Avatar
RRT vette
The engine will not turn over without the CCM. It is also where the mileage is stored. I believe the PKE can be removed without problem.
Old Jan 29, 2008 | 07:13 PM
kalister1's Avatar
kalister1
No for the PKE either, at least in my 93.
Old Jan 29, 2008 | 07:36 PM
robertallen's Avatar
robertallen
ok i must know what is a ccm and pke and what do they do???
Old Jan 29, 2008 | 07:45 PM
kalister1's Avatar
kalister1
CCM = Central control Module
I guess it is the interior computer, holds mileage, VIN, talks to the ECM = Engine Control Module, the programmed chip and the engine computer, PKE = Passive Keyless Entry, key FOB that sends a signal to the car to open the door when you walk up.
Old Jan 29, 2008 | 07:57 PM
robertallen
wow im learning alot THANK YOU
To Ccm
