Dyno Results - '95 LT1 A4
Old Jan 29, 2008 | 11:38 PM
USA1LT1's Avatar
USA1LT1
Default Dyno Results - '95 LT1 A4
Here are my dyno results for my '95 LT1 A4:
265 rwhp and 287 lbs-ft torque on a dynojet.
Only mods are a Corsa catback, Mid America MAF housing, open air cleaner lid and K&N filter.
What would 265 rwhp convert to at the crank? The guys at the dyno shop said manual tranmission cars have driveline losses of 13% and automatics are closer to 20%.
At 20% driveline losses, my calculated crank hp equals 331.
Does this sound reasonable?
Old Jan 30, 2008 | 12:15 AM
Digital Disaster's Avatar
Digital Disaster
Yes.
Old Jan 30, 2008 | 01:41 AM
No Go's Avatar
No Go
331 for exhaust and an air cleaner...I think on the high side for an LT1.
The Corsa on an LT4 added 17 WHP on a conservative dyno so that is where most comes from.
Old Jan 30, 2008 | 01:43 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
265 for an A4 is about right.
http://forums.corvetteforum.com/show...highlight=dyno
Old Jan 30, 2008 | 01:44 AM
sweetbaboon's Avatar
sweetbaboon
I came up 318 hp if it a 20% loss.
304 for a 15% loss.
Its late so maybe I cant add
Old Jan 30, 2008 | 05:12 AM
Zix's Avatar
Zix
Most relatively stock LT1's run about 260-270 RWHP, so you're sounds like it's right where it should be. However, don't get caught up in the "convert to FWHP" stuff, there's just no way of really knowing, and what's the real difference anyway? Besides, based on most numbers, if you want to use those % conversion numbers than all LT1's and LT4's where underrated from the factory anyway.
Old Jan 30, 2008 | 05:42 AM
bizaro's Avatar
bizaro
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
<--93 LT1 276 RWHP before any mods
Old Jan 30, 2008 | 08:34 AM
RoperC4's Avatar
RoperC4
Time for a supercharger...
Old Jan 30, 2008 | 01:31 PM
gslotman's Avatar
gslotman
Nice numbers for your LT-1 USA1LT1
I believe our Corvettes are a bit more efficient than 20%. (I am not starting the great what percentage should I use debate here again )
As I said - I believe 15% to 18% is more realistic.............
Old Jan 30, 2008 | 01:37 PM
Aurora40's Avatar
Aurora40
304 for a 15% loss.
You can probably add. But no addition is required. 265/.80 = 331.
Old Jan 30, 2008 | 01:42 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
That sounds about right to me. The only experience I have however is my own 95A4 on a mustang dyno.
My base run prior to the LT4 Hot Cam Kit was 252 RWHP and after the cam, rockers, timing chain kit, opti, plugs & wires it went up to 292 rwhp. Again this was on a mustang dyno and I don't know if that makes much difference.
Old Jan 30, 2008 | 07:09 PM
Overboost's Avatar
Overboost
From: Flint Michigan, #2 in unemployment, #3 in Violent crimes
mustang dyno, only way to go. dyno jet sux because it gives an inflated number. mustang dyno is "real world" numbers.
and who cares about fly wheel power? isn't the power we put to the ground what is important?
Old Jan 31, 2008 | 08:12 AM
Z06_BluByU's Avatar
Z06_BluByU
see sig... mustang dyno with stroker motor...
good numbers lad!
Old Jan 31, 2008 | 10:54 PM
crossfire7's Avatar
crossfire7
good numbers lad!
268 rwhp for a 383 stroker?
Old Feb 1, 2008 | 03:10 AM
Z06_BluByU's Avatar
Z06_BluByU
pretty conservative dyno to say the least (mustang eddy currant dyno).. 95* day with 90% humidity.. plus the motor is pretty mild.. not much different than stock except for the cid, cam and valve job.. The torque is whats impressive!!
Old Feb 1, 2008 | 11:09 AM
aboatguy's Avatar
aboatguy
I used a mustang eddy current dyno and ended up with around 100 more hp than your pull and the dyno guy stopped the pull before the curve peaked. I didn't have a tune on it yet.
So you probably would do better with some head cam work. Since I only have a 355, 2800 stall, A4 and factory cat back with EM LT headers and high flow cats.
Once I get out of he sand box I'm going to get it tuned for the current cam/valvetrain and get the puppy back on the dyno . (didn't plan on getting sent to Baghdad and due to unforseen problems got the car on the road a couple of days before I left so the dyno run was the afternoon before I flew out) The AI 200s and the AI custom cams seem to be the HEAT.
If I find a scanner over here, I'll post the untuned graph.
Mike
Old Feb 1, 2008 | 11:58 AM
F1Fan's Avatar
F1Fan
I don't understand going to the expense of stroking it, and then leaving so much on the table with such a mild build. But I suppose you wanted stock sound/drivability.
I kinda like it when the grouchy old ladies in my neighborhood grab their little lap dogs up and scowl at me as I go by. They probably think something is seriously wrong with my car to be so loud.
To Dyno Results - '95 LT1 A4
Old Feb 2, 2008 | 06:23 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I put down 339 rwtq with a stock long block. You've got a lot more power hiding in that motor.
Old Feb 2, 2008 | 10:09 AM
Z06_BluByU's Avatar
Z06_BluByU
When i did it I wanted to just freshen the motor up.. the stroker kit was just about the same cost as stock parts so i figured why not.. I did really need the power (i have another car solely for drag racing). I drive this car to work every day.. its been a great car with a nice sound and a smooth idle.. no problems... shes a dream.. My other car is the monster!!
Old Feb 2, 2008 | 05:42 PM
MR NICE's Avatar
MR NICE
I come up with 318 also put me on the can't multiply list.
