ok, so I buy the nice Pioneer head unit, Bose amp adapter, harness wiring adapter, and dash mounting kit from Crutchfield. Solder it all up, remove my old Bose, go to plug the new harness adapter to the car's factory plug, but it doesnt match up. I call Crutchfield and they tell me that I will need to plug into something else behind one of the seats and totally disregard the wiring in the dash. They say I need to fabricate up about a 10 foot harness and route it from my new receiver to the back of the car somewhere.
The relocation to the rear was a 94-96 move to make room for the airbag.
The '92 receiver is behind the glovebox.
The antenna wire may be long enough to pull back to the center. It is, of course, the little GM style that many need adaptors for.
Sorry, I am in work, not paying attention, you are correct. The three wires you need are on the left side of the box under the glove compartment. You will need to remove the hush panel on the pass. side of the car (the part down by your legs). There are three screws down just past were the carpet ends, and three screws up were the fuse panel is. You must remove the fuse panel door to get to them. You will also need to disconnect the antenna lead form the box (CDM). THe best way to do this is, after the hush panel is removed, remove the air diverter in front of the glove compartment (2 screws). Look down thur the space were the air diverter was, and you should see the box, and the antenna lead. You will need and extension (2 ft) and a adpator, as stated above.
Randy
And if you plan on removing the stock CDM a box of bandaids will come in handy.
