1990 C4 Exhaust
Old Jan 31, 2008 | 03:28 PM
Sweet 90's Avatar
Sweet 90
Default 1990 C4 Exhaust
Hi everyone, This may seem a strange question, but when checking the exhaust at the rear of my car only the two outer tips on each side were working and nothing coming from the inners tips.Are these just fake or do I have a problem. It is a totally stock exhaust actually the original from 1990
Old Jan 31, 2008 | 03:51 PM
JonnyAngle's Avatar
JonnyAngle
That's how they are supposed to be
Old Jan 31, 2008 | 03:52 PM
Sweet 90's Avatar
Sweet 90
Thanks, Jonny, I had never noticed this before just made me wonder
Old Feb 1, 2008 | 01:51 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
I'll bet your car is a non Z51 car. Seems like the Z51 cars got 4 working tips instead of 2.
Old Feb 1, 2008 | 02:43 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I disagree, The original mufflers on my car only had the outside tips working, and my car is a Z51.
Old Feb 1, 2008 | 06:26 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
That's true, my Z51 had only 2 working outlets when I got it. Now it has 4!
Old Feb 2, 2008 | 08:05 PM
Dr. Evil's Avatar
Dr. Evil
CI-IV AutoX Champ
CI-IV Burnout Champ
My 90 had both sides working(all4) as delivered from GM, go figure. I know that there was a reason for it too, be it an RPO code or something. I just cant remember what it is.
Old Feb 2, 2008 | 08:22 PM
Road Agent's Avatar
Road Agent
Old Feb 3, 2008 | 02:52 AM
DDSLT5's Avatar
DDSLT5
How quickly they forget! The muffler tips aren't inoperable - they have small holes in the middle to relieve moisture, but the baffles are there to reflect the exhaust sound waves back into the muffler and cancel out the resonance - they are Helmholtz resonators.
Starting in 88, GM starting offering an exhaust option to gain an extra 5 hp over the stock exhaust system - it removed the baffles and you got 245 hp instead of 240 hp.
Old Feb 3, 2008 | 10:13 AM
Muffin's Avatar
Muffin
And a bunch more resonance.
Old Feb 3, 2008 | 11:45 AM
GUSTO14's Avatar
GUSTO14
I have an '85 Corvette with Z-51 that I ordered new in September of 1984. I came with only the outside pipe flowing exhaust. Absolutely nothing on the inside tip including a "small" hole for moisture. I tried a couple of times to punch a hole through the casing to at least equalize the color of the tips, as the outside tip was always darker than the inside tip. Because of the angle between the tip and the muffler, and the toughness of the original muffler I could not punch a hole through it.
I took it to a friends muffler shop and he used an arc welder to reach in carefully and "burn" a hole into the muffler casing where the dummy tip is welded on. Now all four tips flow equally. (It took 15 minutes and cost me $20!) There was a slight increase in resonance from the modification, but it's not at all objectionable and it also sounds a lot healthier.
Two friends in the past year both purchased '91 Corvettes with the stock exhaust on them and both took them to the same shop and had him open the center of the dummy tip. Both were very pleased with the results.
Good luck... GUSTO
Old Feb 5, 2008 | 02:59 PM
Sweet 90's Avatar
Sweet 90
Hey thanks Gusto, when and if ever we get out of this deep freeze I'll talk to the muffler shop and see if he can do the same for me
To 1990 C4 Exhaust
