L98 Heads
Old Feb 1, 2008 | 08:50 PM
MdVette88's Avatar
MdVette88
Default L98 Heads
I want to get new parts for my heads and I would prefer Comp Cams. So can any1 recommend me any lifters, rockers, springs and pushrods because I have no clue what combination. My Vette is a 88.
Old Feb 1, 2008 | 09:23 PM
rodj's Avatar
rodj
Need more info on what you want to achieve.
Changing cam , what lift , etc ?
If changing pushrods can go to non self aligning rockers which are cheaper than stock self aligning type but you need to replace the pushrod guideplates as well.
Old Feb 1, 2008 | 10:43 PM
MdVette88's Avatar
MdVette88
this is the cam im getting https://www.jegs.com/webapp/wcs/stor...10002_61708_-1
Old Feb 2, 2008 | 02:57 AM
Curveit's Avatar
Curveit
Get the valve springs for that cam. Your pushrods and rockers are ok stock, roller lifters are too, if you don't have too many miles on them. I predict you're going to want a new intake soon after installing new cam.
Old Feb 2, 2008 | 08:16 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Jegs brand has a full set of aluminum 1.6 ratio self aligning full RR's for $229. Part # 555-20145. They also have 1.5 ratio sets. You can use GMPP 101# LT4 springs and retainers for your heads. They are around $35 for the springs. If your seals are good that is all you need.
To L98 Heads
