Runs like a truck in Closed Loop???
I got the codes pulled with the ALDL and A and B connected, and pulled a Code 32 and Code 44. I know that the only thing I have done to it recently was I changed the Plugs, wires cap and rotor as it had only had one tune up its whole life according to the previous owner, and I must say, he was not a mechanic or even close. He had the middle two plug wires on each side crossed, and had not changed the factory plug under the AC. I have it all back to stock, and have cleaned out the K&N filter. Now if I can fix this, I will tackle the Brake light next. It has new brakes, and new master and is great stopping but the Brake light comes on. First want it to run, so I can move it around in the garage, and driveway, then finish diagnosising what else is wrong.
I know that the codes are O2 Sensor and EGR Valve Problem, but most of the time, that would tell me something about either a bad sensor someplace, or a problem with something unplugged, or something. Like I said it runs perfect until the computer takes full control and it gets all confused. This car was a California car its whole life, and now I am in Utah. I was told that I need to change the O2 Sensors out, to a three wire one, instead of the factory one wire one, but no one even glanced under the hood to tell me that. Just a bench estimate of what is wrong. Once I can get it in the garage, and warm I was going to run to the FSM and run the steps to find out what could be wrong with the EGR and the O2 Sensors, but thought while I am working, I could also let the internet, and all the great people on here help me find out what else could be things to check. I am really tight on cash so there is no chance of me just tossing parts at it till I find the problem. Gotta find out what is wrong first, and then fix it right the first time. I know I have a ton of cash needing to be spent as I am told that the little oil leak I have is not so little as my Oil Pan leaks because it is dented all to hell. If I have to replace the pan, my guess is as tight as things appear all over this car, the engine will need to be picked up some, off the mounts, and if I am lucky I can sneak it out. Otherwise it is going to require a major time and investment. Want it to run, then fix things as it goes, and by spring, I want to replace all the window rubber and door and top rubbers, so I can start driving it again.
RACE ON!!!
This all started when it got really cold and snowing around here. Anything else I should check?
By the way thank you very much for your response. That is again proof of how great this site is.
I'm sorry for the "hijack" but I have an '06 C6 w/a manual transmission and am THINKING about selling it to get a C4, 1990-1991 for various reasons.
If your car is a stick, in good shape, clean, and "representative" of a '90 (and you get it running correctly) would you be interested in trading cars for a day or two? I live in Park City so it would definitely not happen until May....maybe June at the rediculous rate that it's snowing!!
-Tom
I appreciate your openess to my idea, and I will be in touch sometime closer to spring time. Again, sorry for the hijack, but I saw "'90" and "Sandy UT" so I had to pitch my sale.
-Tom
Where can I get a two wire weatherpack connector for this, and where can I get the silonoid? Used would work as long as it is a good one, so I can make sure that is the problem.
I am going to also replace the valve cover gaskets on this thing really soon. Looks like I have some work ahead of me.
