Interior lights wont go off
Old Dec 2, 2001 | 03:06 AM
RichAshley-Black99's Avatar
RichAshley-Black99
Default Interior lights wont go off
I washed my car a couple of weeks ago and I cant get my interior lights to go off. So i had to pull the fuse so it wouldnt run my battery down. Ive heard its some sort of light timer but I cant seem to find the part. If any ideas on how to fix this problem please help. Thanks
Old Dec 2, 2001 | 11:21 AM
traxx1's Avatar
traxx1
Default Re: Interior lights wont go off (AshleyRL-87Conv)
The timer you are looking for is on the passenger side, take off the panel under dash above passenger knees) there you will see a white plastic connector it is the interior timer, I think it has three wires to it, unplug and replace,cost about $20 and all will be well again.
:jester :jester :jester :jester
Old Dec 2, 2001 | 11:38 PM
Terry's Avatar
Terry
May just be your door lock.
Had the same problem on the 92.
Make sure your key is 90 degrees before you pull it out of the door. Believe it or not it happens, if you take your key out of the lock before it is back to the "90" degree angle" it can leave your interior lights on. Its bounced around this forum, but I forgot what the reason was, I guess either worn key or tumbler!?
Your mileage may vary!
Good luck
Old Dec 2, 2001 | 11:46 PM
spowers's Avatar
spowers
St. Jude Donor '12
Default Re: Interior lights wont go off (Terry)
Terry, I just figured that out!!! Just got the car last week and Fridaynight I'm driving earning the dork award! Driving around with the int. lights on. Got out curse... swear... lock the door.... ran into the bank... come out lights are out :D It had to be the lock sensor. Dose anyone know how hard is it to replace the lock cylinder??
To Interior lights wont go off
