LT1 balance question
RACE ON!!!
RACE ON!!!
On this same subject, I'm in the process of replacing the 3 seals in the front engine cover (95 LT1, 6 spd, btw). I have everything off (also replacing water pump, Opti w/MSD unit, plug wires, etc.
The damper/balancer/pulley piece is off & I note to re-align the arrow on the back of the damper with the arrow on the crank hub.
Picking up on a reply here, there is no key on the crank ? Re-align at 12 o'clock (TDC) you said. Is there a mark on the cover ?
Naturally, I assume the cam will follow & properly align the dist. rotor.
I know I'm asking obvious questions, but this thing scares me a little...
Thanks for your help.
KLS
KLS
The opti will only go on one way also. Be sure and not force it. Your FSM explains it well.
Hope this helps.
Hope this helps.
As far as I can find out from doing research in it, it is my belief (for what it is worth) that the LT1 damper has holes in it to allow the balancing of the damper by itself before being put on any engine.
According to some of the after-market torsional damper makers, dampers with elastomer that is used to bond an inner (hub) ring to an outer ring cannot be made of perfectly balanced components because the bonding of the rubber is not perfectly concentric. (In other words, if both rings were perfectly balanced before the bonding of the rubber, since the bonding is not perfectly concentric, the rings will be positioned so they won't be balanced anyway).
Therefore, the holes around the damper are to allow the damper to be perfectly balanced after the bonding takes place. In other words, the damper is supposed to be neutral balanced before putting it on the engine.
Some sources of information:
http://www.vibratechtvd.com/VISCOUSTECH.htm
In particular, about half-way down:
Elastomeric Dampers
In elastomer dampers, the outer inertia ring is fixed relative to the mounting hub through a ring (or rings) of elastomeric material (usually rubber). These units must be balanced after assembly to correct imbalance due to any offsets between the inertia ring and the hub that are created by the imposition of the rubber ring between them (note the large balance holes on many of these dampers). An elastomer damper that is not balanced out of the box is not self-correcting at any speed.
Because of this research, I believe that the LT1 elastomer damper is neutral balanced, and the lack of a keyway in the hub goes a long way in agreeing with that. If anyone in their right mind thought the damper position was critical to the balance of the engine, they would provide a way to insure the position.
However, you will read many things on-line that differ with this -- it is up to you to decide what you believe, like I have.
Tom Piper
Elastomeric Dampers
Tom Piper
