Turn signal died
Old Feb 3, 2008 | 10:51 AM
Lars87's Avatar
Lars87
Default Turn signal died
The turn signal on my 96 just died. When I activate, left or right, I just stays steady at either side.
check list:
When Hazzard light is on, all signal flash fine
All bumlbs er ok. ( 2xfront, 2xfront side, 4 rear, 2xrear side 2 x backup)
Sometimes I can get it to blink VERY slow to the right.
Any ideas?
Old Feb 3, 2008 | 01:32 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
check list:
Any ideas?
Turn signal flasher, hazzard flasher is different.
Old Feb 3, 2008 | 02:45 PM
jfb's Avatar
jfb
I concur with Lars87. Hazard flasher is separate from turn signal flasher and all flashers work on current. Lower (burned out bulb) current, slow or no flashing, high current faster flashing. Since all lamps are lit, you must have a flasher at the end of its life.
Lars87's Avatar
Lars87
Hope so...
Is the mechanisme behind the steeringwheel out of the question, when the green arrow shows when i select L/R?
Old Feb 3, 2008 | 07:33 PM
jfb's Avatar
jfb
Yep, replace the turn signal flasher, its not expensive, about $6.
Old Feb 4, 2008 | 05:54 PM
Lars87's Avatar
Lars87
thanks guys...
replaced it today...everything is A OK now...
To Turn signal died
