walbro 255
Old Feb 5, 2008 | 04:27 PM
vett40's Avatar
vett40
Default walbro 255
i am thinking of purchasing a walbro 255 lph fuel pump wondering the good things and bad things about this fuel pump , also where is the place to install it any help would be great thanks
Old Feb 5, 2008 | 05:11 PM
Zix's Avatar
Zix
I have the 255 installed in my car. My first question is, do you need it? The stock pump is more than you need for everything up to some big-budget 383+ of forced induction cars.
The install is a snap, the C4 is probably the easiest fuel pump R&R I've seen! You can take the entire assembly out through the fuel door.
Old Feb 5, 2008 | 07:51 PM
CFI-EFI's Avatar
CFI-EFI
Unless it has, or is, failing, the stock pump bypasses as much fuel as the engine burns, under most circumstances. Is the stock fuel pump not meeting the demand? Are you running out of fuel under high loads at high rpms? If so, a new, stock pump will probably cure the problem, unless you have built the engine where it has a very high demand. Of it is determined that you need it, the proper Walbro pump fits in the stock location. There is no need to look for a place to install it.
I am CFI-EFI, and I approve of this message.
RACE ON!!!
Old Feb 5, 2008 | 07:56 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
RACE ON!!!
VERY appropriate!!
Old Feb 5, 2008 | 08:51 PM
Red Tornado's Avatar
Red Tornado
RACE ON!!!
Old Feb 6, 2008 | 08:02 AM
Happydad's Avatar
Happydad
RACE ON!!!
We Missed Ya.....
Old Feb 6, 2008 | 10:34 AM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
I've got one on my TPI Z-28, and is quiet and reliable, but I really don't NEED teh extra pressure. I was
going to put a 383 in it before I got teh Vette, so I went heavier, preparing for teh bigger motor. I'll buy
another one if and when teh OE Vette one goes...
Old Feb 6, 2008 | 10:51 AM
pmihaltian's Avatar
pmihaltian
Slingshot
The fuel pumps on C4s start to act up and fail at about 75000 miles or so. Accordingly, if you have a high mileage C4 and it has the original fuel pump, you should consider changing it as it will likely fail at the most inopportune time. I installed a Walbro pump a year or so ago and it works just fine.
I have attached a WORD file documenting how to remove and install a new fuel pump. Good luck.
File Type: doc
Old Feb 6, 2008 | 11:45 AM
CFI-EFI's Avatar
CFI-EFI
Changing tehfuel pump won't change teh pressure, unless teh new pump is of such a high volume and teh fuel system is so restricted that it can't handle tehextra volume.
Thanks for the welcome back, guys.
RACE ON!!!
Old Feb 6, 2008 | 04:36 PM
vett40's Avatar
vett40
thanks for the infor just what i was looking for i need this pump to top my winter project going after 425 rwhp . head work ,intake work, cam,electric water pump, long tube headers, stall converter 3.54 gears 30lb injectors 58 mm tb here is picture
Old Feb 6, 2008 | 05:11 PM
Happydad's Avatar
Happydad
Very Pretty.....
Old Feb 6, 2008 | 06:21 PM
pmihaltian's Avatar
pmihaltian
Slingshot
WELL DONE ! Very
To walbro 255
