'Split Oxygen Sensor output?
Old Feb 6, 2008 | 02:18 AM
whalepirot's Avatar
whalepirot
Default 'Split Oxygen Sensor output?
I would like to install a wideband oxygen sensor readout w/o running a second sensor. Can I split the feed, and send to both the ECM and a gauge? My headers are hot coated and I'd rather NOT have another bung welded in.
Old Feb 6, 2008 | 11:53 AM
redrose's Avatar
redrose
my oem narrow-band sensor seems happy feeding the ecm, an a/f gauge, and a laptop...all at the same time...wideband ??
Old Feb 6, 2008 | 12:03 PM
Matt Cramer's Avatar
Matt Cramer
It depends on the controller, but it's doable. I know Innovate wideband controllers have a narrowband emulator output; not sure about others (I work for an Innovate retailer). The ECU and the gauge will need separate outputs since the signals they need are different.
Old Feb 6, 2008 | 01:33 PM
whalepirot's Avatar
whalepirot
Default Entering a new learning curve, here
Thanks for the replies.
How is that set up? I thought wideband referred to the sensor, a Bosch heated sensor and was capable of giving more detail to a gauge while reacting faster to changes in the exhaust gas.
I have some homework to do, I guess. By controller, you mean the O2 sensor?
The car has a '90 Camaro ECM with a modified harness, keepallowing a stock location (front of the passenger, under the dash). The rest of the engine management is relatively stock, despite the engine being far from stock. With this aggressive cam running the engine on the edge of a stock systems capability, I'd like to watch the air/fuel ratio more closely rather than wait for an O2 failure, or CE light.
Thanks for your patience with my learning curve.
Old Feb 6, 2008 | 03:01 PM
redrose's Avatar
redrose
wide vs narrow refers to ''range'' that the sensor has varying output voltage (an oem ''narrow'' band sensor does not provide discernably different outputs in the ''power'' range of a/f mixture but only is useful near 14.7:1)...a ''heated'' sensor comes ''alive'' and sends useful data to the ecm sooner than an unheated sensor -- can be either narrow or wide band, but (due to cost) oem heated sensors are all (AFAIK) narrow band...reaction time of either far exceeds speed reqd....''heated'' sensors do provide miniscule reduction in emissions at cold start and are reqd if the exhaust system design (thin-wall long tube headers, for example) allows the sensor to cool below operating temp.
btw, 600*F is ''generally accepted'' as the temp at which oem narrow band sensors start sending useful data (voltage)
To 'Split Oxygen Sensor output?
