procharger d1r rebuild help
I would see if I could get answers from ProCharger.
Aaron
Aaron
ATI states that their head units have a 10% minimum over design built in, which would mean that their bearings are capable of >70K RPM.
Best of luck in your bearing replacement.
Aaron
Aaron
On my '87 with the D1R, I am running a 7.2" diameter drive shive (crank), with a 3.4" driven shive (blower). At 6200RPM engine, the calculated blower speed is ~58.3K. That is pretty much at MIS.
I guess my bearings are just fine with 58K, and as i know I sometimes run to 6350, maybe they do have that 10% built in.Boost is a relative term. I am probably getting less boost than others might due to the large heads, large cam, and my intake/TB. I have minimal restriction in the intake tract. I am typically right at 25 psi, sometimes touching 26 psi (depends on ambiant air temp). One time I logged and saw just over 28, but that has not been repeated.
I am not sure what amount of boost you will see with yours, as I do not recall your intake components, nor cam. Details? I/C?
Aaron
Aaron
.btw when i was 16 i had a 83 z-28 with a ho 305 that made 500+h.p and thats no Last edited by makn u shiver; Apr 29, 2008 at 06:01 AM.
old combo
Fully forged bottom end, but with SRP pistons, Crower rods, GM block (2-bolt)
s.c.r. - 9.5:1
blower - ProCharger D1
Heads - AFR215CPs
Cam - CC HR ~228/236@0.050", ~0.600" lift
Intake - MRII w/ 58MM TB
IC - 4 row custom FMIC Spearco
Boost - 9.5 psi @5800, 12 psi @ 6300
intermediate combo
Fully forged bottom end, but with JE custom, Oliver Billet rods, Callies S/L, GM block (splayed 4 bolt)
TBs.c.r. - 9.2:1
blower - ProCharger D1R
Heads - AFR215CPs
Cam - CC SR ~248/254@0.050", ~0.670" lift
Boost - 9.5 psi @5700, 12.0 psi @ 6400
intermediate combo II
same fully forged bottom end
Heads - AFR220CPs
Cam - CC SR ~248/254@0.050", ~0.670" lift (same)
Intake - C4SP w/MB
Boost - 8.5 psi @5500, 10.8 psi @ 6400
current combo
Heads - AFR220CPs
Intake - C4SP w/MB
IC - none; EtOH injection
Boost - 9 psi @3400, 18 psi @ 4500, 24 psi @ 6050, have seen 26+ (once 28)
Best of luck in breaking into the 14s.
Aaron
