Car is an 84. All of the electrical appears to be working fine, with the exception of my brake lights. Some kind old lady pulled up next to me on the way home today and informed me they were out. I have checked the bulbs and fuses on the passenger side. Can anyone give me some suggestions here? Is there another fuse or switch possibly? The tail lights to turn on when I pull the headlight bulb, they just do not light when I apply the brake.
Have you checked the switch on the brake pedal arm? I don't have a book or first hand knowledge of the '84 but these switches are typically closed when the brake is NOT engaged and open when the brake IS engaged. There should be power to the switch on both terminals when the pedal is up and only on one leg when the pedal is down. So, with the switch disconnected, the brake lights should be on solid. Again, I don't know the '84s so it could very well be the reverse of everything I wrote here but either way your next stop (pun) is the switch.
I will test the wires tomorrow morning. If they check out fine, does anyone know if this switch is tied into any relays behind the dash?
The Haynes manual I have is pretty vague.
You obviously are not getting 12v to your rear harness stop light circuit or the ground maybe bad. Suspect it isn't your ground as everything esle seems to work-right? Think the only things that can go wrong at this point would be every bulb bad, the rear harness connector near the front of passenger door needs checking or cleaning, the brake pedal switch is incorrectly adjusted or needs replacement, or something else that will just frustrate you. Do you get 12v across the fuse terminals? I would really suspect the brake switch first. Take the two-wire terminal connector off the switch and put a jumper wire in--if your brake lights come on it is in your switch. I have an 84 also and the circuit is extremely simple-maybe? I'll stick with you until you get her fixed.
BURN the Haynes Manual. Contrary to confusing ans self contradictory information above, the stop light switch is a N.O. (normally open) switch. Depressing the brake pedal closes the circuit sending 12 volt power to the stop light filaments of the rear bulbs. It could hardly be much simpler. It is a conventional stop light circuit. There are no relays in the system. The power does flow through the 4 way hazard switch, but it isn't likely that's part of the problem. Most likely it is a maladjusted or defective stop light switch. BTW, the fuse is labeled, "Stop Haz". Next, visit www.helminc.com and order a proper FSM for your car, to replace that charred Haynes.
The bulbs are the common 1157s and have two filaments. The circuit routes through the flasher b/c the stop and flasher uses the same, brighter filament.
I modified my car to export type lights and ran a single wire from the brake ON/switch CLOSED side straight to the (now two) brake lights; no relay, as was stated.
The bulbs are a bit of a PITA to reach but it is possilbe that they all failed at some time, not necessarily at once; just never got changed. Checking one bulb may be easier than pulling under dash panels, etc.
Before you start all that jumping wires and pulling bulbs, do the hazard lights work? This is the same circuit and the same bulb filament as the brake lights. Also does the turn signal lights work? Again same circuit. If "yes", then it is simply the brake light switch. A very easy part to replace.
Thank you all for the help and suggestions. The first thing I did last night when reading the brakes shared the same circuit as the hazards was to check to see if my hazards worked. Sure enough, they did. I went to advance first thing this morning, picked up a new switch... viola!! I now have brake lights again. Thank you all!
Disregard my stupid posting here. I hadn't read the humorous reference to "burning the haynes manual". I thought the burning reference was about the jumper wire.
I need to be enlightened? For those who are worried about toasting marshmellows, then don't ever step on your brake pedal again! Touching a jumper across this brake switch connector has the same effect as the plastic brake switch closing the same circuit. If your brake lights don't come on then the problem isn't the brake switch. It will be somewhere else in the circuit. What do I not understand here about this 20A fused brake/hazz circuit? I have a 58, 72, 84, 88 and 90 with essentially the same brake switch operation and now I am afraid to step on any of the brake pedals for fear of all of them burning up when the circuit closes! Not trying to be sensitive. I just really want to understand these things too.
Reason: My error
