Wheel fitment on 84...
I want to put the grand sport/ collector edition style wheels on my 84. I have read that some change occurred in 88 that prevent a simple wheel swap. I know this is a noob question, but appreciate your help. Thanks!
-Scott
Just because a wheel fits without rubbing doesn't mean it'll look right. The wheel dimension that effects it's appearance on the car is what I call "front spacing". It measures from the hub to the outer bead and determines the placement of the wheel relative to the wheel well. Once you exceed a certain frontspacing, the tire sticks out past the fender. You calculate it by subtracting the offset from half of the wheel width. For a zero offset wheel, the front spacing distance is simply half of the wheel width, got it? So check the chart below for what wheels your car has on it. Then compare it's frontspacing with any other wheel to see if you need adapters to make up the difference. (Also, backspacing measures the distance from the hub to the inner bead, plus a little extra for the wheel lip. If you exceed a certain backspacing, the tires will rub in the fenders. I haven't calculated backspacing yet.) (WIDTH / 2) - (OFFSET / 25.4) = FRONT SPACING OEM CORVETTE WHEEL FRONT SPACING: 84-87 base 8.5"/2 - 32mm/25.4 = 2.99" 84R-87 Z51 9.5"/2 - 38mm/25.4 = 3.25" 88-96 base 8.5"/2 - 56mm/25.4 = 2.05" 9.5"/2 - 56mm/25.4 = 2.55" (also used for fronts on some models) ZR1 rear 11"/2 - 36mm/25.4 = 4.08" Grand Sport rear 11"/2 - 50mm/25.4 = 3.53" C5 base 8.5"/2 - 56mm/25.4 = 2.05" 9.5"/2 - 65mm/25.4 = 2.19" C5 Z06 9.5"/2 - 54mm/25.4 = 2.62" 10.5"/2 - 58mm/25.4 = 2.97" C6 base 8.5"/2 - 56mm/25.4 = 2.05" 10"/2 - 79mm/25.4 = 1.89" C6 Z06 9.5"/2 - 40mm/25.4 = 3.18" 12"/2 - 59mm/25.4 = 3.68"Power Steering Trivia
http://www.marketworks.com/storefron...46820&c=332068
Lots of different finishes available. Reasonably priced and over all a pretty nice wheel.
I bought a set a few years back for my '85 and have been very happy with them. Mounted a set of Goodyear GS D3's and have been even more pleased with them.
Good luck... GUSTO
