96 LT1 Running Rough at Idle
A being the lt green and blk wire
B being the lt green and wht wire
C being the lt blu and blk wire
D being the lt blue and wht wire
I hope this helps.
1. Still running rough
2. I can hear the EVAP motor spin up from time to time when starting but not every time I start the car.
3. About the time the EVAP stops making "noise" the idle really goes to the dogs
4. It takes a little longer to start than normal
5. There is now a definate miss
6. And she is running hot - boiling over (suppose this means we are running lean - right?)
I have sprayed carb cleaner around everything and can not find an vacumn leak. The miss is inconsistant or so it seams. Anyone with any ideas would be deeply appreciated.
Like
Are the Plugs fouled?
Do you have the right plugs?
Is there a Spark plug wire burnt, arcing?
MAF is it damaged?
Check the tips of your exhaust, is there black residue?
Try to find suspected vacuum areas and test them by removing while car is running to see if there is a change.
Just my input.
Also, what is the EVAP motor?
Thanks,
Doug
1. Spent hours with my best friend GOOGLE researching the problem.
2. Wore the search engine out on this forum. Read every post remotely related to my problem.
3. Sprayed everything down with Carb cleaner searching for vacuum leaks. Actually found a couple of hoses that were not leaking but needed to be replaced.
4. Cleaned the throttle body and replaced the IAC. No improvement.
5. Eliminated an individual cylinder problem by unplugging one plug wire at time.
6. Did the same test with injector leads for each cylinder.
** In my case I presumed it was not a fuel delivery problem as the she did not starve for fuel when driving. May be faulty logic but it worked for me. Therefore, I did not check the fuel pump (other than to hear it wind up) nor the fuel pressure in the fuel rail.
While drinking XX Guinness and ponding the problem I decided to start the car a few times and just listen. I noticed that the EVAP system would run for a few seconds at start up and the vehicle seemed to fun fine until it stopped. The idle would go to the dogs at this point. That just happened to remind me of a similar problem I had on a C1500 which I had bent the EGR valve while working on it. So...
7. I applied direct vacuum to the EGR from the manifold power brake port. Observed no movement. Manipulated the diaphragm with a screw driver and noticed it worsened.
8. Removed the EGR valve and confirmed that it was sticking. I cleaned it with Valvoline Throttle Body Cleaner till it moved smoothly and then reinstalled it. The car ran fine afterward.
Regarding the EVAP question:
Evaporative emissions from the fuel system (fuel vapors) are trapped and stored in a charcoal canister. Later, a purge valve opens allowing the vapors to be sucked into the engine and reburned. The EVAP system usually requires no maintenance. The fuel filler cap is also part of the EVAP system, and is designed to keep fuel vapors from escaping into the atmosphere. A leaky or missing fuel filler cap may cause a vehicle to fail an emissions test. Also check out this link:
http://www.search-autoparts.com/sear...58/article.pdf
With the engine off, I was looking and feeling at the EGR valve to see what I could move. I was able to push on something and I could push it in and it would spring back. I assume this is the diaphragm. So if it is able to move as described, does that eliminate the EGR?
Also, I understand that the canister in my 95 is located behind the passenger side wheel well. Where did you "listen" to be able to hear something running?
Thanks,
Doug
