Are all LT1 Heads and intakes the same? I'm looking for parts to a 4 bolt block and I'm not sure if I have to match the intake/heads to my 93?
LT1 heads have two different castings. Fitment will not be an issue between the two castings.....but the 1995 and later castings will perform slightly better than the pre-1995 castings.
The intakes are slightly different.....I think the intakes for the 1992 and 1993 models are specific to the intake because they have a groove at the top for a crossover line.
With the heads, I know aluminum heads were put in corvettes, camaros, and firebirds. I intend to send them off to Eportworks so does it matter what kind of heads I should be looking for? Specifically corvette heads or the 10128374 as described?
Its not just the 374's that are good for porting. The 643's are also very good for porting. Those 2 are the desired casting's. The 561's are the late 96 F and Y body heads and 97 F-body heads. As mentioned they flow better in stock form. Any intake will work on your single crossover tube setup. If you got a later style intake you would have the unused extra grove for a 2nd crossover. But it will still work.
