E brake question...................
Old Feb 7, 2008 | 05:58 PM
Z51JEFF's Avatar
Z51JEFF
Default E brake question...................
Should the E brake handle in a 91 have a spring that brings it to the floor once its set?
Old Feb 7, 2008 | 06:25 PM
Steel Blue 91's Avatar
Steel Blue 91
No spring. Just pull it up to set it and then push it down. To release it, pull up until you feel resistance and the button can be depressed. Hold the button in and push the lever down.
Old Feb 7, 2008 | 08:36 PM
Z51JEFF's Avatar
Z51JEFF
Ive got an 84, once the E brake is set a spring brings the handle back down to the floor,I thought the 91 was the same.Thanks for the reply.
To E brake question...................
