1984 G110 Ground Location
Old Feb 8, 2008 | 03:20 PM
tgtexas02's Avatar
tgtexas02
Default 1984 G110 Ground Location
Where exactly is this G110 ground? Is this the ground on the driver forward pillar?
Old Feb 8, 2008 | 06:15 PM
jhammons01's Avatar
jhammons01
Is G110 the name given in the FSM?
Old Feb 8, 2008 | 06:44 PM
CFI-EFI's Avatar
CFI-EFI
Page 8A-127. "On LH rear of engine"
Page 8A-82, Figure 8A-67
I am CFI-EFI, and I approve of this message.
RACE ON!!!
Old Feb 8, 2008 | 07:12 PM
tgtexas02's Avatar
tgtexas02
CFI, you are a good man! You are making my harness corrections easier. Thank you for fast response. My harnesses were a mess but with each correction they are all coming together just like a grand plan--just like they are suppose to be. Thanks you..
Old Feb 8, 2008 | 07:27 PM
jhammons01's Avatar
jhammons01
Well let me ask this.
Based on that picture, When CC and I did my clutch we had to take that bolt out to get the Tranny off.
We would have re-grounded it when we put it back together correct?
The reason I ask is because I was thinking to do it for maintenance, but if it was recently tweaked, then I am not going to worry with that one.
Old Feb 8, 2008 | 10:46 PM
tgtexas02's Avatar
tgtexas02
I am sure you have a good ground if you aren't having any electrical problems (especially the cluster). On my 84 I actually have this ground as a threaded hole in the block very near the transmission mounting hole (same difference). The battery ground cable is there along with a couple of other ground ringlets and I have a metal braided ground strap there too. The other end of the strap and the small battery ground wire are then attached to my right frame rail top with a single metal type screw/bolt. Might be more than you wanted to know if your ground is okay and I am sure it is.
To 1984 G110 Ground Location
