Dumb question
Old Feb 11, 2008 | 04:42 PM
ernie22golf's Avatar
ernie22golf
Default Dumb question
Can a stock 1990 L98 run on the 87 octane low grade fuel we now have?
Old Feb 11, 2008 | 04:45 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Will run yes.....will it knock yes!
Old Feb 11, 2008 | 05:32 PM
vader86's Avatar
vader86
Yes, but it'll cut timing which hurts mileage, among other things.
It should run best on midgrade fuel, but you have to use a scanner to be sure.
Old Feb 11, 2008 | 06:30 PM
CFI-EFI's Avatar
CFI-EFI
Not all cars are the same. Some will, some may not. The best way to find out about your car, is to take a drive with a recording scanner attached and check for knock counts or timing retard on play back. For your terrain and style of driving, you may be just fine.
RACE ON!!!
Old Feb 11, 2008 | 07:06 PM
jghmczo6's Avatar
jghmczo6
I have a '90 and the gas tank opening states "high test only".........as does the owners manual......................
Old Feb 11, 2008 | 07:08 PM
ernie22golf
Default A recording scanner?
What is a recording scanner and where would I get one. Thanks sorry I'm still operating in the 1970's. Hoping to move forward.
Old Feb 11, 2008 | 08:13 PM
CFI-EFI's Avatar
CFI-EFI
Forget the scanner. Wait until the tank is nearly empty and put in 5 gallons or so. Even if it were to knock like crazy, you could still dilute it with better gas since you left plenty of room in the tank. I have my base timing set a 14° BTDC (stock is 6°) and I use 85 octane with no pinging. Admittedly, out cars are quite different.
RACE ON!!!
Old Feb 11, 2008 | 08:16 PM
BADDUCK's Avatar
BADDUCK
The 1990 has 10.25:1 compression IIRC. That is not normally compatible with 87 octane gas. With your timing retarded the car won't run at it's potential.
My 1989, running near sea level, needs 89 octane to run properly and my compression ratio is 9.5:1.
My advice is to run premium like GM advises.
To Dumb question
