Spark checker tool thing
New wires, plugs, cap, rotor,fuel injectors, fpr, checked tps, iac, etc etc etc. Can not find any vaccum leaks with propane or spray whatever.
My main question here, has anyone used the spark checker light that goes between the plug and the wire. (Thought I may be able to spot an irregular spark pulse there. Thinking I might have an ignition module going flakey or a broken wire in the distributor). Was wondering if they can hold up under the voltage of the HEI system.
Opinions appreciated, thanks!
If you have tubular headers another trick is to spray water on each tube.. the one that evaporates the slowest is the cylinder with the problem.
