Well, I may finally have my '93 back on the road next week. What kinda of power do you think she'll make?
383 forged rods and pistons and balanced , K&N filter, 52mm TB, LT4 intake, Ported and polished LT4 heads, a slightly bigger can than the HOTCAM, 30# SVO injectors, 155L/Hr wahlbro fuel pump, Meziere electric water pump, EM long tubes. The MSD opti is going on this week and I still have the tune from PCM for Less when I did the LT4 top end and HOT CAM. I will get the chip re-done as soon as I get it on the dyno. I just got the ECM back from the rebuilder too...I cant wait to get her on the road....
I was making around that with just the LT4 top end Hotcam, Long tubes, 52mm TB and the tune....I would hope a 383 would make more than 400hp at the Flywheel.......LPE lists their 383 LT4 at around 450hp at the fly...I'm sure they are conservitive with their numbers...
Whatever it ends up being...it sounds like it will be bad a$$ and faster than what you had to start. I'm looking forward to getting a 383 dropped into my 86.
