Something to think about is your current brake lines. Are your current lines in good enough shape for the extra heat. The reason I say this is that I am in the process of putting in 610 fluid and at the same time I am changing over the current brake lines due to age. I don't think they would have held up very well to the increase in heat.
Something to think about is your current brake lines. Are your current lines in good enough shape for the extra heat? The reason I say this is that I am in the process of putting in 610 fluid and at the same time I am changing over the current brake lines due to age. I don't think they would have held up very well to the increase in heat.
