Crossfire cam options/ suggestions
Old Feb 12, 2008 | 08:40 PM
psychosurfer's Avatar
psychosurfer
Default Crossfire cam options/ suggestions
After doing some searching I have come to understand that the factory 84 vette has pretty small combustion chambers. Much of the information I have found seems to suggest that a cam will not do too much as a result. What have your experiences been? I want to (obviously) make as much power as possible while retaining as much of a stock look as possible.
Looking forward to your opinions/ suggestions...
Old Feb 12, 2008 | 09:18 PM
qws's Avatar
qws
I would recommend that your first mod would be to port your intake. Its a cheap and will give you good gains that are noticable, I would say at least a 35hp gain. There are other options out there that you can search out as well, but the best bang for your buck is right there!
Personally I use the 2040 cam in mine and like it. I have other mods as well. One of the best resources for mods on the 84 is located here...http://www.crossfire.homeip.net
You can easily get wrapped up in the crossfire... I have! Its a fun car to play with. I'm to the point now where I've started to do my own tuning.
Old Feb 13, 2008 | 12:10 AM
Curveit's Avatar
Curveit
The above is good advice.
psychosurfer...
The combustion chamber is not small; the 128 & 113 have smaller chambers (58cc), and that doesn't really have anything to do with the cam anyway. Perhaps you're talking about ports?
Old Feb 13, 2008 | 01:41 AM
xrcrx's Avatar
xrcrx
I concur, I used the Crane 2040 in my '84 also. Good gains and ecm friendly.
Old Feb 19, 2008 | 07:38 PM
psychosurfer
Sounds like a good direction for a cam, thanks! I was referring to the size based on how much a cam would "matter." (a side note, I am a good parts installer, but always needing advise on what to install) Several sources note that the combustion chamber is too small on the stock heads to optimize from the additional lift and duration an aftermarket cam would offer.
That said, Im hearing only good things, from people WITH these engines and cams that have had success.
Im gonna go hit up jegs right now and get one ordered. Ive got roller rockers on the car already. I am planning to port the intake at the same time as the cam install. Any more "moves" I should make while I'm at it?
Old Feb 20, 2008 | 12:26 AM
qws's Avatar
qws
If your gonna have that much apart I would suggest changing the heads. Myself I used the Dart ss. They are iron but do flow nicely. A lot of us guys do use them. They're pretty cheap. The flow around 173cc but are advertised at 165cc. Or go aluminum, if you so desire.
But let me add to this, if your gonna change all that and to get the most out of it tuning is in your future. So think about how involved you want to get before just going out and replacing a lot.
Old Feb 20, 2008 | 12:55 AM
Curveit's Avatar
Curveit
Like I posted above, combustion chambers really don't have anything to do with the cam. Port size does. You're getting bad info from someone who doesn't know what they're talking about.
qws... 173 & 165CC are port capacity (size), not flow. One head with a 180CC port might flow 200CFM, while another brand will flow 250CFM from a 180CC port. It pays to inquire and shop around.
Old Feb 20, 2008 | 12:59 AM
xrcrx's Avatar
xrcrx
You want an LSA of around 114, and duration of 215-225 at 50. That will keep it ECM friendly-chips don't work, forget about 'em. Porting the intake, Heads with intake runners of no more than 190cc's max-you must maintain intake flow velocity or you'll kill the low and midrange, along with the cam and you'll have a car well into the 13's.
Old Feb 20, 2008 | 02:03 AM
qws's Avatar
qws
Let me rephrase: They are advertise as 165cc, but the true measured intake and exhaust port volume is 178cc. Sorry to confuse you by using the word flow
http://www.chevyhiperformance.com/te...ad_racing.html
Old Feb 20, 2008 | 02:21 AM
Curveit's Avatar
Curveit
Then they're just lying then; advertizing those flow numbers as comming from a 165CC port, when it's actually a 178CC port. It still doesn't flow worth a crap compared to AFR 180CC heads.
Old Feb 20, 2008 | 02:37 AM
qws's Avatar
qws
I don't know if there lying or not. Its a pretty good article comparing 5 or six different heads.
I won't disagree with your comment on AFR's heads but I never compared the two. All I was trying to say is that for those on a budget build those heads are pretty good at only $625. If the OP is going to swap heads they are worth looking into
Old Feb 20, 2008 | 01:07 PM
xrcrx's Avatar
xrcrx
Just because the number is big doesn't make it the best for a given application. Too much and you kill the low end and even the mid range.
Old Feb 20, 2008 | 02:02 PM
Demonic85's Avatar
Demonic85
'84 heads have a 76cc combustion chamber and somewhere around 160-170cc intake runners. If your heads are in good shape, then a cam will be just fine. Its the valve springs that you have to worry about breaking if they're worn out.
Old Feb 20, 2008 | 02:31 PM
CFI-EFI's Avatar
CFI-EFI
On both points.
Can YOU explain what "optimize from the additional lift and duration" means? That sounds like the double talk of someone that has no idea what they are talking about. Just for the record, the 76 cc combustion chambers of the L83, Crossfire, 624 heads, are about (if not) the BIGGEST combustion chambers of ANY SBC, and certainly no where near the smallest, or too small.
Are you saying that both the intake and exhaust ports are 178 cc? That is an awfully big exhaust port for a SBC. Actually, impossibly large. Or are you saying that someone has inexplicably added the two port volumes together, to produce a TOTALLY meaningless number?
RACE ON!!!
Old Feb 20, 2008 | 02:52 PM
qws's Avatar
qws
Originally Posted by CFI-EFI;1564185803
Are you saying that both the intake and exhaust ports are 178 cc? That is an awfully big exhaust port for a SBC. Actually, impossibly large. Or are you saying that someone has inexplicably added the two port volumes together, to produce a [I
TOTALLY[/I] meaningless number?
RACE ON!!!
Good catch! I wouldn't want to give out any misinformation.
It should have been typed as 178cc/70cc
Old Feb 20, 2008 | 06:00 PM
Curveit's Avatar
Curveit
Flow numbers aren't gonna hurt you, it's big port size( CC ) that will hurt the bottom-mid range power, on too small a motor. You lose the velocity. Match the heads to the engine size, and planned use.
As for those heads listed above: while certainly cheap; probably Chinese, if I ordered and set up my motor for 165CC heads and they came through 178CC I'd be pizzed. Would be if the numbers were reversed too. I can see a couple of CCs off for machineing errors, but not 13. I'd be questioning the rest of the machine work myself.
Old Feb 20, 2008 | 06:21 PM
xrcrx's Avatar
xrcrx
That was exactly what i was referring to. Lotsa people figure if 180 is good 210 is better, then 215 must be best. Heads,cam,intake, exhaust-it all must work together. As for those heads , i can't say-13 is way too much, I'm using Darts myself.
Old Feb 20, 2008 | 07:02 PM
CFI-EFI's Avatar
CFI-EFI
10-4. Gotcha.
Between two heads with equal flow numbers, the head with the smaller port volume is the better choice. The flow velocity will be higher and the ports more efficient.
Those port sizes referred to are probably, "as cast", but a 13 cc variation is HUGE and intolerable.
RACE ON!!!
Old Feb 20, 2008 | 07:10 PM
qws's Avatar
qws
Easy to think but they are dart iron eagle ss heads that are reconditioned.
Absolutely.
For me, I knew what they were before I purchased them and for what I wanted they worked.
To Crossfire cam options/ suggestions
