1988 electronic heater controll
Old Feb 12, 2008 | 11:51 PM
chopper56's Avatar
chopper56
Default 1988 electronic heater controll
Have heater set to heat and only get cold air heater hoses are hot, any ideas what might be wrong?
Old Feb 13, 2008 | 02:27 AM
pablocruise's Avatar
pablocruise
I have a hunch it is loose solder joints on 2 resistors that are on a circuit board.
* Note: caption is misleading, resistors were not burned out, just the solder was loose
That's the "good news".
The "bad" news is, it is located on the interior side firewall, behind the brake pedal, next to the steering column and will require you to contort your body into awkward positions to reach.
You'll have to remove the hush panel, and look for a black plastic box.
It has one crazy nut holding it IIRC(it's been years since I did the same fix on mine).
Old Feb 13, 2008 | 04:01 AM
86PACER's Avatar
86PACER
Best to just pull the driver seat so you can lay flat. Contorting your body to get under there gets old real quick.
Old Feb 13, 2008 | 08:25 AM
Da Mail Man's Avatar
Da Mail Man
before you REALLY get involved with this, check the plastic clip on the blend door which connects the actuator motor with a rod that connects to the blend door......if that is broken or stripped out, you will have the conditions you describe (and in reverse also!).....
Old Feb 13, 2008 | 06:55 PM
chopper56's Avatar
chopper56
Thank you will check these ideas...the blend door connection is it on the firewall side of heater?
Old Feb 13, 2008 | 07:02 PM
Da Mail Man
look up INSIDE of the passenger floor-board area after removing the "hush' panel...you'll see a small motor attached to the heater box...on that motor you'll see a rod attached with a clip to the motor... on the other side of that rod that you can see ONLY after removing the heater resistor from the heater box in the engine compartment, you'll see another clip that attaches the rod to the "blend" door....if either clip is stripped or broken, it will and can cause the problem you are having.....*also, just to sure, disconnect the battery for a few minutes to see what (if any) effect this will have)...
Old Feb 13, 2008 | 07:25 PM
chopper56's Avatar
chopper56
Sounds like this could be the problem because when you drive it after a few turns on the road you get heat.
Old Feb 13, 2008 | 07:28 PM
Da Mail Man
Old Feb 13, 2008 | 10:17 PM
pablocruise
ok, then do this:
(except DON'T split the case)
and look down into the cavity to see the clip circled in yellow:
This is the one INSIDE of the car:
Can't get that one without major surgery.
Old Feb 13, 2008 | 10:21 PM
Da Mail Man
..i figured that someone would post these sooner or later since i misplaced my copies........also, the clips are no longer manufactured by gm...i found a source for the clips but, have to "re-find" that info......may not even be relevant here yet....
Old Feb 15, 2008 | 02:30 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default heat
you want heat? pull the vacuum line off the heater valve. it will be stuck in full hot!!!!!!!
hint: you need to find out if you have vacuum at the heater valve all the time.......
Old Feb 15, 2008 | 11:11 PM
chopper56's Avatar
chopper56
Thank you guys and for the pictures (89 Paul in Cal) looked in the heater hole by the firewall and the blend door would move freely so knew something was not hooked on, it is the clip under the dash on the motor the little clip is broken so will have to find a new one or something that works, little hard do get to when you are upside down and legs over the seat, than try to get out... Pays to have friends that have worked on these before.
Old Feb 16, 2008 | 10:42 PM
chopper56's Avatar
chopper56
Just a follow up..Got a clip today not the exact one but got it to work, took afew hours, trying different tools until it snaped into place put it back together and now, I HAVE HEAT.
Thanks Again
Old Feb 17, 2008 | 09:00 AM
Da Mail Man
To 1988 electronic heater controll
