Spark plug cutback?
Old Dec 4, 2001 | 12:47 AM
BAdAzZV8's Avatar
BAdAzZV8
Default Spark plug cutback?
I have heard different numbers when people talk about the spark plug cutback. What are these numbers that you are talking about? Like someone put .035 as a dimension, and also put that with ignition stuff to use a .05 so what dimensions are we talking about?
Old Dec 4, 2001 | 01:22 AM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Spark plug cutback? (BAdAzZV8)
Well I just read some more posts, and see that it refers to gap, but gap between what?
Old Dec 4, 2001 | 03:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The gap is like the gap on a standard spark plug, the air gap between the center electrode and the outer ground electrode.
A stock ignition has enough power to create a spark in the mixture with the standard gap; a higher energy ignition usually has more power so the gap can be increased to enhance the mixture burn efficiency.
Old Dec 4, 2001 | 04:44 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Spark plug cutback? (65Z01)
Alright thanks, I am going to be ordering some ignition stuff and plugs and wires, so I will cut the plugs when I get them.
To Spark plug cutback?
