Oil Leaks
Oil Leaks
I have some small oil leaks (besides the bigger Opti leak in the front) that have got me lost and annoyed and :mad . The oil drip is just above the third freeze plug at the back of the block on both sides Any ideas ?
Re: Oil Leaks (AquaMetallic94LT1)
Head gasket, intake gasket, valve cover gasket? If you do replace gaskets buy the high quality brands and save yourself future headaches! :yesnod:
Cruise-In II Veteran
Re: Oil Leaks (Camvette)
LT1's leak oil everywhere I am slowly learning. Rolls Royce used to call it "controlled seepage". If its good enough for a rolls its good enough for my Vette :D
